450cc injectors from a Mitsubishi
Old Aug 15, 2011 | 05:00 PM
ArithMEHtik's Avatar
Default 450cc injectors from a Mitsubishi
They are stock dsm injectors. Does anyone know if I will need a resister box or anything else to throw these in my b16? If so where I can get them as well?
Old Aug 15, 2011 | 05:44 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 450cc injectors from a Mitsubishi
Throw them in your B16 for what purpose? If they are low impedance they will need a resistor box.
Old Aug 15, 2011 | 07:33 PM
EsotericImage's Avatar
Retired Moderator
+1
you just cant throw in injectors, even tho they might be the right impedance and expect the engine to perform better.
why are you looking for shitty used DSM injectors?
Old Aug 15, 2011 | 07:42 PM
sde780's Avatar
Accords will have the resistor box. I wouldn't just throw them in unless you have a chipped ECU and basemap/tune for those injectors. Also I had mine cleaned and flowtested by a guy on here, personally I don't like risking my motor on a set of iffy injectors.
Old Aug 15, 2011 | 07:50 PM
This is a swap I am getting. Its a b16 cylinder head with gsr cams V-tec locker set up and a b18 b1 block also arp head studs. A friend of mine has these injectors and I was told it would be better that my stock injectors for this set up. Thoughts?
Old Aug 15, 2011 | 07:52 PM
I am also getting a p28 chipped ecu for this set up.
Old Aug 15, 2011 | 07:53 PM
Sorry for the lack of information right away my fiance was pulling me away from the pc
Old Aug 15, 2011 | 07:55 PM
Retired Moderator
well, if its a LSV, then you will have to tune anyways.. I would get a fresh set of 440's and new feul pump for 269 @ xenocron. But thats what I would do..
Its your $$, so do what u want buddy.
+1 on risking engine on used, iffy injectors.
Fast
Reliable
Cheap
Pick 2 and the 3rd is what its not.
heres a link to help you out
http://www.xenocron.com/fuel-pump-in...3a918f9125b2ab
Old Aug 15, 2011 | 07:56 PM
Retired Moderator
Is the engine together? or do you need to mate the head on the block still?
Old Aug 15, 2011 | 07:58 PM
Thanks for the advice and the link very helpful and a good deal. I think I will go with new instead of used, I will be getting it tuned right away also.
sde780's Avatar
It's only better if you get a tune and are sure the injectors flow good. You don't want to randomly pull 450's from the junkyard and throw them in your car.
The engine is together yes.
Old Aug 15, 2011 | 08:01 PM
sde780's Avatar
http://hondamarketplace.com/showthread.php?t=2893979
Check that link out...I got my injectors from him, top notch service and very cheap!
You can send him your 450cc as a core...ask him how much it is because I remember it was cheaper to just send him mine as a core and he'll send out a fresh set.
They are from my buddies galant he wouldn't give me trash or anything, but I am most likely buying new.
Old Aug 15, 2011 | 08:03 PM
Retired Moderator
youll prob need clips with the new set also. And i recommend the extra $$ for the Walbro pump.
Honda-Tech = Awesome you guys have been a great help to me I thank you all very much for the input and suggestions!
Old Aug 15, 2011 | 08:08 PM
Where can I find the clips? or would they be with the set on xenocron?
Old Aug 15, 2011 | 08:09 PM
Herp Derp, I need to use my eyes before I post. They are on the site, thank you again.
sde780's Avatar
You can use OBD0 Civic injector clips or OBD1 civic and use a razor blade to cut a little notch out of the injector clip. The link to the guy I posted, if you get rebuilt ones off him they'll be already notched to fit OBD1 clips. You can't beat his price.
Want a Walboro? This was where I got mine, cheapest place I found on the internet, legit, and fast shipping ($79 shipped with install kit!)
https://honda-tech.com/forums/forced-induction-49/walbro-pump-w-kit-79-shipped-rc-injectors-2819191/
Old Aug 15, 2011 | 08:10 PM
Retired Moderator
http://www.xenocron.com/replacement-...3a918f9125b2ab
or the plug and play
http://www.xenocron.com/rc-injector-...3a918f9125b2ab
Thats a great price for a walbro WITH install kit!
Old Aug 15, 2011 | 08:12 PM
Love the options I have thank you guys.
sde780's Avatar
$269 at Xenocron for injectors and walboro is kinda pricey...I paid $70 for a rebuilt set of DSM 450cc (after sending mine in as credit..paid $50 for those) and $80 for a walboro.
$70 + $50 + $80 = $200 instead of $269 at Xenocron. Chris at Xenocron is a great guy but I'm just sayin'...you save $69 if you go through people on this forum.
Old Aug 15, 2011 | 08:15 PM
That is true, I appreciate all the work you guys are doing to help me.
Old Aug 15, 2011 | 08:19 PM
This could just be my lack of knowledge but since its not all the same b series motor meaning (b18 and b16) what fuel pump would I get? Integra or Civic?
Old Aug 15, 2011 | 08:20 PM
Retired Moderator
either. its the same
i like the options as well..ill have to bookmark that link. thx 780
