450cc injectors from a Mitsubishi
They are stock dsm injectors. Does anyone know if I will need a resister box or anything else to throw these in my b16? If so where I can get them as well?
Re: 450cc injectors from a Mitsubishi
Accords will have the resistor box. I wouldn't just throw them in unless you have a chipped ECU and basemap/tune for those injectors. Also I had mine cleaned and flowtested by a guy on here, personally I don't like risking my motor on a set of iffy injectors.
This is a swap I am getting. Its a b16 cylinder head with gsr cams V-tec locker set up and a b18 b1 block also arp head studs. A friend of mine has these injectors and I was told it would be better that my stock injectors for this set up. Thoughts?
Retired Moderator
well, if its a LSV, then you will have to tune anyways.. I would get a fresh set of 440's and new feul pump for 269 @ xenocron. But thats what I would do..
Its your $$, so do what u want buddy.
+1 on risking engine on used, iffy injectors.
Fast
Reliable
Cheap
Pick 2 and the 3rd is what its not.
heres a link to help you out
http://www.xenocron.com/fuel-pump-in...3a918f9125b2ab
Fast
Reliable
Cheap
Thanks for the advice and the link very helpful and a good deal. I think I will go with new instead of used, I will be getting it tuned right away also.
It's only better if you get a tune and are sure the injectors flow good. You don't want to randomly pull 450's from the junkyard and throw them in your car.
http://hondamarketplace.com/showthread.php?t=2893979
Check that link out...I got my injectors from him, top notch service and very cheap!
You can send him your 450cc as a core...ask him how much it is because I remember it was cheaper to just send him mine as a core and he'll send out a fresh set.
You can use OBD0 Civic injector clips or OBD1 civic and use a razor blade to cut a little notch out of the injector clip. The link to the guy I posted, if you get rebuilt ones off him they'll be already notched to fit OBD1 clips. You can't beat his price.
Want a Walboro? This was where I got mine, cheapest place I found on the internet, legit, and fast shipping ($79 shipped with install kit!)
https://honda-tech.com/forums/forced-induction-49/walbro-pump-w-kit-79-shipped-rc-injectors-2819191/
Retired Moderator
http://www.xenocron.com/replacement-...3a918f9125b2ab
or the plug and play
http://www.xenocron.com/rc-injector-...3a918f9125b2ab
Thats a great price for a walbro WITH install kit!
$269 at Xenocron for injectors and walboro is kinda pricey...I paid $70 for a rebuilt set of DSM 450cc (after sending mine in as credit..paid $50 for those) and $80 for a walboro.
$70 + $50 + $80 = $200 instead of $269 at Xenocron. Chris at Xenocron is a great guy but I'm just sayin'...you save $69 if you go through people on this forum.
This could just be my lack of knowledge but since its not all the same b series motor meaning (b18 and b16) what fuel pump would I get? Integra or Civic?
