head options for b17a1
Old Aug 15, 2011 | 06:30 AM
hamilton9339's Avatar
Default head options for b17a1
I have a 92 gs-r w/ the b17a1 DOHC VTEC I jumped timing an bent my valves just trying to figure out my options for a head swap till I can afford the head rebiuld figure it'd be the cheaper way to go for now. Any info is helpful & telling me to do a swap ain't an option im staying with the original motor thanks
Old Aug 15, 2011 | 12:29 PM
m_shake's Avatar
Default Re: head options for b17a1
Any b-series vtec head will work, but a b16/b18cr head will work out the easest.
Old Aug 15, 2011 | 01:06 PM
PyroProblem's Avatar
Swapping in new valves is probably the easiest and cheapest way. Why don't you want to do that?
Old Aug 15, 2011 | 01:45 PM
I don't got the special tools to do it but an engine shop just told me $1000+ for them to do it even if I provide parts so I might be tool shopping
Old Aug 15, 2011 | 01:50 PM
k20ekhatche85's Avatar
I whould use b16 type r head depends if u wanna go boost or all motor >
Old Aug 15, 2011 | 03:46 PM
Get in contact with steve at cccylinder heads. Im sure he can get your head fixed up to tip top shape for way less than a grand.
Hes got a great rep and from what I've seen, great prices and great customer service...
Old Aug 16, 2011 | 07:53 AM
m_shake's Avatar
Why would that matter for N/A or boost?
Old Aug 16, 2011 | 07:58 AM
kyden's Avatar
well its not really that easy. i've never seen a bent valve that hasn't trashed a guide.
Old Aug 16, 2011 | 08:59 AM
Red_Army's Avatar
so guides are whats making this cost a 1k? still a rip.
look around for the tools or a better shop.
Old Aug 16, 2011 | 04:03 PM
IDK, Ive bent valves before and the guides were ok. Not just on Hondas either...
Old Aug 16, 2011 | 04:08 PM
DDTECH's Avatar
Machine shop quoted you 1k?? LOL..
Normal charge for a hot tank, VJ, install new valvetrain and valves w/ seals and guides should be around 300-500..max.. if you supply the parts.
I'd listen to pryo and look for a set of valves around and outsource it to another machine shop.. lol.. 1k.. thats too funny.
Old Aug 16, 2011 | 04:26 PM
m_shake's Avatar
Dude, I had Larry @ Endyn port my gsr head, install bronze guides, hot tank it, and a valve job for just about $1k...you are getting ripped!!
Old Aug 16, 2011 | 06:26 PM
Ok so found a head its a b18 Vtec but its tapped ofr LSV will this still work? Sorry new to engine parts swapping
dntnedvtec
36
Mar 5, 2025 08:41 AM
the_dxB16
Jul 20, 2009 02:18 PM
1LastOption
Oct 11, 2007 10:40 AM
jasonhasahatch
Mar 6, 2007 02:11 PM
fliptout
Feb 10, 2006 03:49 PM
