Identify This Head
Old Feb 9, 2006 | 05:41 PM
fliptout's Avatar
Default Identify This Head
I bought this head from a guy who knew less than I did. The markings on the head were as follows. Pr3-3 and then what I beleive was a date stamp that read: 9|9 0|4 0|1 9|0. I need to know so that I can get the ecu and the rest of the parts for the swap.
Old Feb 9, 2006 | 06:01 PM
QUAILMAN's Avatar
Somebody correct me if i am wrong, but I believe it could be a B16 head. Do you have any pictures, did it come w/ cams ?
Old Feb 9, 2006 | 06:04 PM
fliptout's Avatar
Default Re: Identify This Head (fliptout)
I dont have pics right now but yes it came with cams, springs, Valves, Valve Cover, but no vtec solenoid.
Old Feb 9, 2006 | 06:05 PM
bks84's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fliptout &raquo;</TD></TR><TR><TD CLASS="quote">I bought this head from a guy who knew less than I did. The markings on the head were as follows. Pr3-3 and then what I beleive was a date stamp that read: 9|9 0|4 0|1 9|0. I need to know so that I can get the ecu and the rest of the parts for the swap. </TD></TR></TABLE>
That means its a B16 or Type R head. That was made in 1999 so, its either a Si head or a Type R head.
Old Feb 9, 2006 | 06:08 PM
QUAILMAN's Avatar
Default Re: Identify This Head (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">
That means its a B16 or Type R head. That was made in 1999 so, its either a Si head or a Type R head.</TD></TR></TABLE>
and a beer for you... I forgot about type R...D'oh
fliptout's Avatar
So would I need a P72 ECU? or a P73?
Old Feb 9, 2006 | 06:10 PM
bks84's Avatar
Loved
p30 p61
QUAILMAN's Avatar
P72 is GSR, it depends on what you want to do. If you want the same ECU that goes w/ the head, then no. What kind/year of car is it going in? ....edit....bastard beat me to it.....
Old Feb 9, 2006 | 06:13 PM
fliptout's Avatar
Default Re: (4sd4dr)
p30 is for 92-95 obd-1 Del Sol DOHC Vtec Si/EG Sir
P61 is for 92-93 obd-1 Integra GSR
Neither is a 99
Old Feb 9, 2006 | 06:23 PM
QUAILMAN's Avatar
Default Re: (fliptout)
the 99 Si ECU is a P2T and as you already know the Type R is P73 but....What kind/year of car is it going in, you can run pretty much any ECU in about any car these days w/ all the jumpers that are out there......
Modified by AZsREDex at 9:37 PM 2/9/2006
Old Feb 9, 2006 | 06:56 PM
bks84's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fliptout &raquo;</TD></TR><TR><TD CLASS="quote">p30 is for 92-95 obd-1 Del Sol DOHC Vtec Si/EG Sir
Neither is a 99</TD></TR></TABLE>
i know this. but, if you'd specify what car this is going in, we can help determine what ECU is needed. expletive it, you can run a PM6 w/turbo edit on that head if you wanted to and were obd0.
so, specify the year make model of the car and you'd get a better answer. I assumed you were OBD1, so mentioned the rarest ECU's I could.
Old Feb 9, 2006 | 07:07 PM
fliptout2's Avatar
Sorry this is a restricted account, only 5 posts. It is an 90 integra ls
Old Feb 10, 2006 | 03:49 PM
QUAILMAN's Avatar
Default Re: (fliptout2)
you have an obd0 car, so your gonna have to do a little wiring and/or changing a couple things to run that head in your car( such as your distributer..). Your best bet is an obd1 ECU w/ a jumper, or find an obd0 B16 ECU. Your possibilties are numerous, so now you just need to do a little research and come up w/ whatever you think would work best. Chipped P28's are a pretty common ECU, however if you are going to keep everything stock, I would recomend a stock ECU. such as the P30, P61, etc... Just research, you are not the first person to do this so I bet someone already has a write up, or all the info you need somwhere...
arcbruce
Jul 4, 2008 09:29 AM
v!taminb16
13
Feb 15, 2008 07:01 PM
dixie Normas7
Sep 27, 2006 01:32 PM
cacahead1
Jun 11, 2005 07:29 AM
Home Skillet
Dec 6, 2003 09:43 AM
