b16b vs b16a3
Old Aug 14, 2011 | 10:44 PM
bradabu's Avatar
Default b16b vs b16a3
i have a fresh b16a3 block with ACL race bearings and arias 11.1 comp but just got an offer for a b16b (ctr) block all stock...what you you guys run??
im going N/A and i have a built head...
also use the ctr trans or ls?
thanks
Old Aug 15, 2011 | 02:28 AM
virgineg6's Avatar
Default Re: b16b vs b16a3
Id stick with the a3 block, and you definitly wanna go with the ctr tranny
Old Aug 15, 2011 | 02:31 AM
BryanM.'s Avatar
Resident Gearhead
I would rather have the B16B and it's tranny.
Honda assembled motors FTW.
Old Aug 15, 2011 | 09:09 AM
DOHCED8's Avatar
yea the ctr would be better. stock they rev to 9k. the block is the same deck height as a b18c, but uses the same crank as the b16 with longer rods and of course ctr pistons. so if you have a built head you would be good to go.. and personally ls trans are worthless unless your turbo or want gas mileage. so ctr is a good choice..
and tear down the block n make sure everything is in good condition.
Old Aug 15, 2011 | 09:34 AM
bradabu's Avatar
would my ACL race bearings from my b16a3 fit into the ctr? main and rod
Old Aug 15, 2011 | 08:03 PM
DOHCED8's Avatar
yea. the crank is the same. just the rods are longer
Old Aug 15, 2011 | 08:30 PM
EsotericImage's Avatar
Retired Moderator
Originally Posted by DOHCED8
and personally ls trans are worthless unless your turbo or want gas mileage or drive alot on highways. so ctr is a good choice..
fixed
blk_eg4
32
Feb 20, 2007 10:43 PM
detroitdiscounts2000
Oct 13, 2006 10:00 AM
str8drift
Jul 10, 2005 03:04 PM
blackspoonem
Dec 28, 2003 01:20 PM
94CivSi
13
Oct 13, 2003 10:19 AM
