2000 SI with H2B setup NO SPARK HELP!!!
Old Aug 14, 2011 | 06:35 PM
tanner_pimp101's Avatar
Default 2000 SI with H2B setup NO SPARK HELP!!!
I have a H22A in my 2000 civi si. I went for the first start up and nothing, gets fuel and turns over just fine but no spark. It came with an internal coil but since there was no spark i put in a external coil dizzy and still nothing. I know for a fact the ecu is good, all the grounds are hooked up along with the one on the thermostat. I have no idea what to do can someone please help.
Old Aug 14, 2011 | 07:21 PM
Former User's Avatar
Default Re: 2000 SI with H2B setup NO SPARK HELP!!!
Go back to the stock coil. Does battery voltage reach the coil and ICM on the Blk/Yel wire? Is fuse 9 blown?
Old Aug 14, 2011 | 08:07 PM
Whats ICM? and ya power reaches coil and Im going to check the fuse now.
Old Aug 14, 2011 | 08:11 PM
Make sure voltage also reaches the ICM (Wht/Blu and Blk/Yel wires) inside the distributor and have an auto parts store test the ICM for you.
Old Aug 14, 2011 | 08:45 PM
ok coil gets power, both of those wires get power, thats all that got power inside the dizzy and which is fuse 9
Old Aug 14, 2011 | 08:46 PM
Fuse 9 is fine if the coil and ICM have voltage. What voltage did you measure? Have the ICM tested next.
Old Aug 14, 2011 | 08:48 PM
I didnt test the voltage just with a test light to see if they were getting power
Old Aug 14, 2011 | 08:49 PM
I checked the CEL codes one was IAT high voltage and the other was P1259
Old Aug 14, 2011 | 08:51 PM
Neither would prevent spark.
Old Aug 14, 2011 | 08:54 PM
So what should I do, I was going to take it to a shop but since it's an H2B swap I figured they wouldnt really know
Old Aug 14, 2011 | 08:55 PM
Did you read my posts?
The Yel/Grn wire attached to the ICM should also have voltage.
Old Aug 14, 2011 | 08:56 PM
o sorry missed that part
Old Aug 14, 2011 | 08:57 PM
ok if that is bad what do i get a new one for since the usdm prelude dizzy are different from jdm
Old Aug 14, 2011 | 08:59 PM
If the ICM tests bad, replace it with what you currently have, assuming you have the correct distributor.
Old Aug 14, 2011 | 09:06 PM
I cant find an H22 dizzy with an internal coil thats y I tried putting an external in it
blake22
Nov 15, 2009 11:57 AM
00EckoSI
Nov 9, 2009 08:23 AM
jaskuloski97sh
Jul 1, 2007 09:12 PM
