2000 SI with H2B setup NO SPARK HELP!!!
I have a H22A in my 2000 civi si. I went for the first start up and nothing, gets fuel and turns over just fine but no spark. It came with an internal coil but since there was no spark i put in a external coil dizzy and still nothing. I know for a fact the ecu is good, all the grounds are hooked up along with the one on the thermostat. I have no idea what to do can someone please help.
Re: 2000 SI with H2B setup NO SPARK HELP!!!
Make sure voltage also reaches the ICM (Wht/Blu and Blk/Yel wires) inside the distributor and have an auto parts store test the ICM for you.
ok coil gets power, both of those wires get power, thats all that got power inside the dizzy and which is fuse 9
So what should I do, I was going to take it to a shop but since it's an H2B swap I figured they wouldnt really know
ok if that is bad what do i get a new one for since the usdm prelude dizzy are different from jdm
I cant find an H22 dizzy with an internal coil thats y I tried putting an external in it
jaskuloski97sh
07-01-2007 09:12 PM
