1992 Accord ABS No Pressure
Old Aug 14, 2011 | 01:25 PM
mikey1968's Avatar
Default 1992 Accord ABS No Pressure
Went through a lot of troubleshooting on this one.....reservoir is full. I can run the pump manually, but nothing out of the bleeder. I tried the hand pump pressurizing the reservoir to get the pump to pick up the fluid. No luck....tried swapping the accumulator from a working one off eBay...no luck. Tried cycling each solenoid manually and manually running the pump over and over again....no luck. The solenoids clicked...each one....pump runs....everything seems to work but still no pressure....any ideas (other than disconnecting the ABS light)?
Thanks,
Mike
Old Aug 14, 2011 | 01:46 PM
exb18c1's Avatar
Default Re: 1992 Accord ABS No Pressure
Start from the begining ,man!What's the problem the car is having .Is it the hydraulic problem or electrical?ABS system has different codes.Why did you go straight to the pump?Manually the pump is working, but is the computer that have to control it.
Old Aug 14, 2011 | 07:59 PM
mikey1968's Avatar
Code thrown was hydraulic problem....nothing out of bleeder = no pressure...already checked the relay, fuse, etc. for code 1.....pump, if running electrically, usually is not the failure mode....bad check valve would pump up then bleed off...usually....since the solenoids click OK...don't think changing that will fix it, although I have a used one I could put in....
Bottom line is, individually, it looks like each component works but.....no pressure....
Old Aug 15, 2011 | 06:55 AM
exb18c1's Avatar
Just to clarify,the bleeder you are talking about is at the ABS pump? What are the symptoms when you step on the pedal.The ABS pump is only for buinding pressure in the reservoir.The actual pressure for application for the brakes comes from master cylinder.The role of the ABS pump/module is to modulate (release and hold) the pressure not to apply.
Old Aug 15, 2011 | 07:30 AM
mikey1968's Avatar
Actually, it's the bleeder at the modulator with the solenoids....this system is the old one where the pump and accumulator are under the battery and the modulator is up by the firewall. The shop manual says to bleed the modulator....there should be residual pressure at the bleeder at the modulator if the system is working properly...no pressure, then you get the motor over-run Code 1....I also checked all the lines for kinks. Perhaps I have two bad accumulators?
Old Aug 15, 2011 | 09:52 AM
exb18c1's Avatar
Does the car have brakes or no?If there is air trapped in the system pedal would go to the floor.Is the master took some air?Did you bleed the master properly?Check if you have the pressure before modulator.
Old Nov 5, 2012 | 02:30 PM
Jeff96-993's Avatar
I threw the same code 1 on my '93, and the ABS light is on. Where did you get the diagnostic tree? I'll assume it came from the service manual, since my Haynes manual has zero info on the ABS system.
Is there a link anywhere to the service manual?
h22_4g
Jul 29, 2018 09:59 PM
steviez
Jan 31, 2018 01:29 PM
EHondaJDM
Dec 14, 2010 05:04 PM
dan123
Sep 11, 2008 06:38 PM
braggindad
Jun 27, 2003 09:10 AM
