Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
ignition problems
Old Aug 14, 2011 | 07:58 AM
kindness's Avatar
Default ignition problems
i wonder if anyone out there can help me, i have a 1995 odyssey(japaneese import) the engine starts up first time but then cuts out unless i hold the key in place, does anyone know how to repair or replace the barrel cheaply.
Old Aug 14, 2011 | 10:54 PM
90sedan's Avatar
Default Re: ignition problems
It's more than likely the electrical portion of the ignition switch and not the ignition cylinder itself.
Old Aug 21, 2011 | 12:33 PM
kindness's Avatar
I have found that if i wedge the key with something into the normal running position that it stays running and that after a few minutes i can remove the wedge and the key will stay in place, which leads me to think that it is a barrel issue. Also i know that there was a recall for the ignition barrel, on both left and right hand drive models, and i was wondering if there might be anyone out there who has had similar issues, and knows how to rectify this.
Old Aug 31, 2011 | 04:04 PM
Orangegsx's Avatar
I've never seen this on an odyssey but many time on civics. Actually happened to me while I was on a road trip and had to jam my shift **** in between the key and the dash... Replaced the ignition switch.
Cliffmmt
Honda Civic (2006 - 2015)
Apr 14, 2019 03:09 PM
eihpd
Dec 30, 2012 01:49 PM
histoboy
Apr 27, 2011 05:38 PM
BlkGSR
Mar 7, 2004 06:28 AM
