Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
should i replace ignition if it is not wanting to take key?
Old 12-28-2012, 04:41 AM
eihpd's Avatar
Icon6 should i replace ignition if it is not wanting to take key?
My ignition is starting to become extremely sensitive to the key placement. Ive figured out the exact position to get the key to slide in but it is definitely sensitive. Ive resulted to leave a key in the ignition and locking the doors with another key. Do you think I need to replace it or fix a mechanical problem in the tumbler?
Old 12-28-2012, 04:56 PM
KWayRacing's Avatar
Default Re: should i replace ignition if it is not wanting to take key?
some locksmiths have success rebuilding sidewinder ignition switches. Do both keys you have perform the same way or is one key more "sensitive" than the other. If so a worn or damaged key may be at issue. If you replace your ignition switch you will then have 2 different keys(one for door and one for ignition) and you will need to have the ignition switch programmed to the vehicle by a dealer.
Old 12-29-2012, 04:25 AM
eihpd's Avatar
both keys act the same. There is definitely a problem in the tumbler and it has been brought to my attention that Im also a target for theft so leaving the keys in the ignition much longer is not smart.
Old 12-30-2012, 01:49 PM
KWayRacing's Avatar
No not very smart at all. Since both keys act the same way either have your ignition cyl rebuilt or buy another and have it rekeyed but keep all exisitng immobilizer compoonents to avoid reprogram. Or just get the dealer to replace and reprogram while your car is still driving avoiding tow fees,
pepsi813
05-19-2019 12:37 PM
biglob
Honda CR-V & Element
05-07-2018 03:50 AM
EricUSC
11-01-2003 09:38 PM
Quick Reply: should i replace ignition if it is not wanting to take key?
