Weird idle issue
I put a 70mm skunk2 tbody on my car and now it won't idle. I have checked and rechecked and checked again my tps voltage. With key on I have 0.5v at what would be idle and 4.6v at wot. The only way I can get this to idle is to adjust the throttle plate stop screw. I did't think I should have to adjust that, but it's the only way to get it to idle. It doesn't matter if its hot or cold. I also tried unplugging the idle air control valve and it stalls when unplugged. The weird thing is that the idle speed screw does nothing. I took it all the way out and it had vaccum there. Could there be something wrong with the tbody itself? As far as I know the coolant lines are ran correctly. I compared it to the acura parts diagram. That diagram is hard to make out. I don't have the gsr intake manifold anymore. Running skunk2 intake. The only thing I changed is the tbody.
The a/f it at 11.5 to 1. I know it rich. Tune is in the working. Hopefully it will be in 2 weeks, when the shop is open on a saturday that I can make it there. I still don't understand why the idle speed screw isn't doing anything?
I did. Took it out completely. That is the only way that screw will do anything, is if I take it out. Put my finger over the hole and stalled. But like it is sayed in this post https://honda-tech.com/forums/showthread.php?t=2919680. Its the way the tbody is designed. The idle speed screw only allows 75rpms of adjustment. That post is very informative. Had I known that I wouldn't have bought a skunk2 tbody.
TB123
Jul 3, 2014 07:38 PM
SilverSellout
12
Feb 27, 2004 12:48 PM
