93 civic with vtec swap which wire harness to use?
i have a 93 civic dx im swaping in a 94 delsol si d16z6 motor into it
should i use my 93 dx wire harness and wire up vtec or use the 94 d16z6 automatic wireharness
my car civic dx (stick)
the motor from 94 del sol si D16z6 (automatic) with wire
Use your stock harness and just add the 3 pins you need for vtec. Do you have the cabin harness side too?
Yeah unless you run the wires from the shock tower harness to the ECU if you use the Si harness its easier just to add the wiring for VTEC solenoid and pressure switch from the sensors to the ECU.
civic-steve-94
15
Jun 7, 2011 07:07 PM
capbyrd
Oct 14, 2004 12:34 PM
TheMostSadistic
Apr 24, 2003 11:15 AM
