Excessive shaking at 7700 +RPM
Old Oct 3, 2002 | 08:37 AM
akhom's Avatar
Default Excessive shaking at 7700 +RPM
Hi, I got a 97 integra GS-R and when drag raing at rpm over 7700 I get this hard shaking. from the motor or trans. I can really hear and feel it shaking via the shifter. I do have ES shifter bushings. Anyone else like this or is it only me?
Old Oct 3, 2002 | 01:52 PM
D-Man's Avatar
Default Re: Excessive shaking at 7700 +RPM (akhom)
I have 3 guesses
either
1 An Axle going bad
2 Clutch going bad
3 Crankshaft Balancer/Pulley is bad
it also could be a misfire in the engine
Old Oct 3, 2002 | 04:04 PM
Finest's Avatar
What about motor mounts? Check those first.
Old Oct 3, 2002 | 06:08 PM
BONER's Avatar
Default Re: Excessive shaking at 7700 +RPM (Prelude_RCR)
I have same problem. Somewhere above 7K the car vibrates. You can really feel it on the pedal when I hammer it. It's massaging. Is that a big problem? How do I go about checking it out? There are no check engine codes being thrown.
Old Oct 4, 2002 | 12:56 AM
CM-R's Avatar
Default Re: Excessive shaking at 7700 +RPM (BONER)
most likely motor mounts..i had that problem with my ek...
Old Oct 4, 2002 | 02:19 AM
ninesecrx's Avatar
Default Re: Excessive shaking at 7700 +RPM (CM-R)
either axles or wheelbearings...
Old Oct 4, 2002 | 10:47 AM
BONER's Avatar
Default Re: Excessive shaking at 7700 +RPM (ninesecrx)
Maybe it could be the wheel bearings. I just dropped the gsr in my ek. All mounts were in tip top shape. I put in new axles though. Couldn't be that...Hmm...
Old Oct 4, 2002 | 04:05 PM
Wide Open Throttle's Avatar
same problem, high frequency vibration at 7k+. i have an aftermarket crank pulley, and i think it was a bad idea.
Old Oct 4, 2002 | 08:12 PM
D-Man's Avatar
I highly doubt its the wheel bearings,if they where that bad,you probably wouldve noticed them when you changed the axles and they usually dont do something like that,they usually just make a humming sound,like when you drive with snow tires.
Old Oct 4, 2002 | 10:09 PM
saso
Guest
Posts: n/a
New axles mean nothing when dealing with FWD and hp. I would check the axles first, cause its always the culprit. I dont think it would be a mount if it was it shouldnt vibrate like that.
Old Oct 5, 2002 | 04:21 AM
aznmc16's Avatar
Default Re: Excessive shaking at 7700 +RPM (saso)
i feel jerks on my car when i did 140 today. when i let off the gas, it started jerking pretty hard... every second a jerk...
Old Oct 5, 2002 | 04:02 PM
saso
Guest
Posts: n/a
Default Re: Excessive shaking at 7700 +RPM (aznmc16)
If its the axle it would only vibrate when you are on the power. If t jerks at pulling off and revving etc. then it could be a mount. You can also try shaking the wheel to check the bearing.
kodylive
Sep 30, 2012 03:43 PM
aojtin
12
Jul 16, 2008 12:48 PM
SalisburyLax
11
Apr 4, 2008 09:44 AM
Mr. Vapor
Jun 2, 2006 11:56 AM
deucedeuceEK9
Nov 25, 2005 06:52 PM
