I'm totally confused....Wierd Vibrations!
Ok,
Last week i raced from a dig against my friend with an LS1-FC RX7. i'm trying to put 400whp through stock axles...im guessing the insane amounts of wheel hop didnt help anything.
fast forward to today, im driving and im noticing some pretty nasty vibrations from the car that i can feel in the shifter, steering wheel and even gas pedal. at first i thought it was a bent/broken axle, perhaps an inner CV. i show no symptoms of a broken CV. boots are in good shape, no clicking during turns (although this would only be the outer joint)
Heres what i found out today.
It only vibrates from about 3900rpms - 4100rpms. THATS is. no place else.
It vibrates in neutral if i reve it to this rev range i still get the vibrations, which tells me it is not the axles since they are not engaged or moving. any ideas?!
upon further thought: Could it be something in the harmonics? Crank pulley? Clutch? flywheel? **** i dunno anyone?
Modified by Mr. Vapor at 8:54 PM 6/1/2006
Re: I'm totally confused....Wierd Vibrations! (b_serious)
I have the inserts, but wouldnt it vibrate all the time?
it LITERALLY only vibrates between 3900 and 4100 RPMs
Mr. Vapor
06-29-2006 04:43 AM
Mr. Vapor
06-02-2006 04:04 AM
