D16y8 running limp?
Old Aug 10, 2011 | 11:55 PM
tony1236's Avatar
Icon2 D16y8 running limp?
Hey Guys
need a some input got my chipped P06 ecu from rywire aswell as the wiring harness and vtec/4wire o2 sensor Harness. trying with The TD-41u dist. Started up right away but my Idle is around 2000. And i cant Rev past 4000 hits like a Rev limiter. (limp mode Perhaps Not spitting Error codes at this time need to hook up a switch so i can see them.) any thoughts would be helpful
Thanks Tony
1989 Honda Si Hatch
D16Y8 Vtec
Old Aug 11, 2011 | 12:17 AM
nemesis3888's Avatar
Default Re: D16y8 running limp?
u sure its not the tune on the ecus chip? duz it lag to get up to 4k rpms?
Old Aug 11, 2011 | 03:14 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
If you have codes then check what they are first... Otherwise most input is misguided. Just ground out (if I recall correctly) D4 on the OBD-1 side, as you don't need a switch.
Old Aug 11, 2011 | 10:20 PM
tony1236's Avatar
no lag i puncher she fly's up to 4k ill check to See if i can get the codes to pop tomorrow thanks for the input guys
Pablo1997
Jun 18, 2016 06:55 AM
ek951
18
Apr 17, 2012 12:09 PM
tony1236
20
Aug 7, 2011 10:05 PM
