D16Y8 HELP!! Vtec not cracking!!
Old 04-16-2012, 11:09 AM
ek951's Avatar
Default D16Y8 HELP!! Vtec not cracking!!
I have a 97 civic d16y8 Im not hearing the vtec crack nor feel it hit. I have read on here to clean out the vtec solenoid did this weekend and nothing. If you have some info or had problems in the past anything will help also the car is stock this is also my first honda ever owned so dont know to much about them either. THANKS!
Old 04-16-2012, 11:15 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Default Re: D16Y8 HELP!! Vtec not cracking!!
CEL codes?
Old 04-16-2012, 11:19 AM
ek951's Avatar
CEL Codes? Sorry man what does that mean?
gold_pwr_r4ng3r's Avatar
CEL= Check engine light
Old 04-16-2012, 11:29 AM
doctorake's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old 04-16-2012, 11:37 AM
ek951's Avatar
No check engine light no pending codes either.
Old 04-16-2012, 11:39 AM
ek951's Avatar
Would i still be able to hear the vtec even tho its stock?
Old 04-16-2012, 11:50 AM
Robin6's Avatar
You can feel the vtec on your D16y8? I could hardly feel mine when I had a sohc as well.
Old 04-16-2012, 11:52 AM
EK9
Dc4LsTeG's Avatar
I don't think its really that noticeable on that engine. What can you rev to?
Old 04-16-2012, 12:13 PM
ek951's Avatar
I'm not to sure I think I've gotten to 6500 but haven't pushed it more than that. I'll see after work today.
Old 04-16-2012, 12:29 PM
Technical Hero
HondaPartsHero's Avatar
does the rev limiter kick in before 7200? Do you have a CEL?
If you answer no to both these questions your VTEC is activating. SOHC VTEC is not that pronounced.
Old 04-16-2012, 03:47 PM
furious94ls's Avatar
If you don't have any codes, it's working. If you really want to hear it buy a short ram or cold air intake. It activates at 5500 rpm.
Old 04-16-2012, 05:48 PM
apexi_rsx's Avatar
If no cel's I would check if your oil is low. Vtec should work with no cel's. That is the only other reason it would not work. U can test the solenoid by hookin 12v to the green and yellow wire on the solenoid and hear it click. Then u know the solenoid is not bad. It's a y8 you will not feel it kick in and hardly hear it either inside the car. This is no k series or b Series vtec
Old 04-16-2012, 06:11 PM
Tony M.'s Avatar
I found your problem
Old 04-17-2012, 11:32 AM
ek951's Avatar
Thanks for your help guys I apperiate it. One more question Short Ram or Cold Air? Which would be better?
Old 04-17-2012, 11:47 AM
Khnemu's Avatar
None. Don't waste your money, buy a nitrous kit and have it tuned if you want cheap power or turbo it which is more complicated.
Old 04-17-2012, 11:55 AM
rice a roni's Avatar
never heard my vtec crack.
Posted from Honda Tech Forum Reader for Android
Old 04-17-2012, 11:57 AM
ek951's Avatar
Kool
Old 04-17-2012, 12:09 PM
ek951's Avatar
I
BSBACKER15
13
09-23-2014 02:30 AM
98civM0bbin
14
08-07-2007 08:40 AM
ITLNstallion818
07-22-2004 10:32 AM
Quick Reply: D16Y8 HELP!! Vtec not cracking!!
