15x8 wheel and 245/45/15 tire help
Old Aug 9, 2011 | 02:39 PM
gosu08's Avatar
Default 15x8 wheel and 245/45/15 tire help
I am wanting to get the hoosier 245/45/15 tire. These are front tires only.
I have some concerns if I get them though:
1. I have a set of 15x7 regamasters to put them on. These would be too small and I would need to go with a 15x8 wheel right?
2. If I run a 15x8 wheel, will I run into any problems? I have spacers if needed and am going to be running extended lug studs.
Thanks
Old Aug 9, 2011 | 03:25 PM
WheaMyRyceGo's Avatar
Default Re: 15x8 wheel and 245/45/15 tire help
Thats a pretty big tire.
I run 225/50/15s Mickey Thompson Drag Radials on my stock 15" ITR wheels with no problems.
Old Aug 9, 2011 | 05:38 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
Although not ideal, there are people who have put 245 tires on a 7" wide wheel. They did that mainly because of race rules limitation.
Clearance issue would vary depending on the offset of your wheel. I imagine that you would need something in the +30's, otherwise it would prolly rub the inside wheel well.
Old Aug 10, 2011 | 06:17 PM
gosu08's Avatar
The wheels are +40 offset 15x8.
Currently running 15x7 regamasters with 225/50/15 micky thompsons but need more tire.
Old Aug 11, 2011 | 10:15 AM
(. )( .)'s Avatar
I'm not a wheel expert but a 40+ 15x8 will rub like crazy on the inner wheel well while turning and will rub trailing arms in the rear. extended studs and slavers are a must IMO
Old Aug 11, 2011 | 10:57 AM
gosu08's Avatar
I will be only running the front wheels.
Those that are running 15x8 wheels, what spacers do you have to use?
The wheels that they will be going on are rota 15x8 +40 offset. I am running the Acura TL lug studs which are longer than the R's but do not stick out past the open ended holes of the lug nuts.
Is the consensus that the wheels will work with a spacer? Probably a 8-10 mm spacer?
I just dont want to spend $700 and be SOL
Old Aug 11, 2011 | 02:51 PM
jdmspoonitr's Avatar
I am running 15x8 with a 3mm front spacer but that is with 225's. The tire does rub against the front frame rail during high G corners.
If this is for drag I think you will be okay with the 245 up front on a 15x8 assuming your car is not dumped to the ground.
For any sort of sport requiring turning, you will have issues with a 245 unless you push it out pretty far with a wheel spacer and either get flares, wide fender, fender spacer or don't mind your tires sticking out way past the fender.
Either way good luck.
Here's my car with 225's.
Old Aug 11, 2011 | 06:29 PM
JGallamore's Avatar
What offset are you running?
Old Aug 11, 2011 | 10:03 PM
Wai's Avatar
Wai
This DC2 runs 15x9 +36 front wheels with 3mm spacer on 245 hoosier slick. The JDM fenders were pulled and barely covered the tires with -3.5 camber.
Old Aug 12, 2011 | 03:19 PM
^^Is he running 245 in the back too? I assume just the fronts, because with 225's in the back of my car it's already running out of room and I'm rolled flat.
Old Aug 12, 2011 | 04:01 PM
oldintegrao's Avatar
For those who have actually ran different widths 205,225,245 how noticeable was the difference/laptimes? Obviously going from a 195 street tire to a 245 hoosier is going to be a change but I'm referring to same type tire and upgrading widths.
Old Aug 13, 2011 | 08:47 PM
Wai's Avatar
Wai
He runs 205 tires on 15x8 wheels.
I see what you mean with 225's in rear, it would give you a nice polished strip on the trailing arm.
Old Aug 13, 2011 | 08:56 PM
Wai's Avatar
Wai
Andrew, I can't really quantify it in terms of lap times or G's, since I don't have enough resources to do back-to-back testing on the same race or track weekend. But one thing I can say for sure is that wider tires, in most cases unless the sidewall ratio is very small like 35 or 40, have much better heat resistence and max load rating. So you get a much more consistent performance over the whole 20 to 30 session or race.
That's also the main reason why I chose to run 225/50-15 instead of 225/45-15 with the mandated RA1 in HC (max load 1201 vs 1323 lbs).
Old Aug 15, 2011 | 01:19 PM
Yah I ran a completely different tire as well, so not really any comparisons on just tire width with the same compound. But I can tell you that 225 RS3's are amazing. I was taking a long sweeper about 3-4 mph quicker (80mph vs. 76ish mph) steady state versus the 195-55-15 star specs I was running on the stock rim.
Old Aug 15, 2011 | 08:13 PM
Thanks for the reply Wai, knowing a time/G difference would have been interesting but thanks for bringing facts into my vague question. I honestly have never paid much attention to load rating on tires. Very interesting, I'm still trying to get the right tire pressure in my RE-11 and a million other things.
JDM, thanks as well!
Old Nov 25, 2011 | 01:11 AM
csm motors's Avatar
Here are my OG sans 15x8
W/ 225-50-50 toyo ra1 35 offset.
stick000008
Feb 8, 2009 07:53 PM
ITR3189
Nov 9, 2007 12:34 PM
K20EF8
Oct 5, 2005 06:38 AM
85mm LS VTEC
Aug 14, 2005 12:42 PM
Rodney
Aug 29, 2002 01:14 PM
