p72 q31 transistor burnt i need different answers
so i understand that this usually occurs from confusing IAT and Evap sensor possibly iacv but...
i had this car running perfect w/ turbo kit on a stock p28 but then i plugged in the demon board p72 with neptune q31 transistor burnt up no others.
it was a used unit so do you think i just got ripped?
or
can a p28 run with reversed sensors and not burn up?
or
The issue is with you having the plugs mixed up.
Your IAT sensor is likely cooked also.
A STOCK p28 can sometimes run with the sensors reversed and it doesn't burn up.
Simply cut the component out of the ecu at q31 and the ecu should function fine.
can any one confirm iat, iavc, and evap sensor wire colors
i notice your are involved with phearable... thats were my p72 is chipped from is there any way you would have the software key for me to access neptune...because the person i bought it from gave us a serial number butn not software key
i understand if you cant help but i cant do nothing until i can get on neptune with the ecu and we are just waiting for the kid we bought it from to find the number
