how come my h22a revs out at 6500 rpm????
Old Oct 3, 2002 | 02:17 AM
Acclude's Avatar
Default how come my h22a revs out at 6500 rpm????
i did an engine conversion on my 92 honda accord ..i put in a jdm h22a and its not running well it revs out at 6500 rpm and there's no vtec, does any one know how to fix this problem????ecu is fine, vtec solonoid and oil pressure swicht is fine....and where can i get the wiring diagram for the h22a???
thanks
Old Oct 3, 2002 | 02:18 AM
illusion's Avatar
Default Re: how come my h22a revs out at 6500 rpm???? (Acclude)
like you said, vtec is not engaging. buy a helms manual.. http://www.helminc.com
Old Oct 3, 2002 | 04:19 AM
Finest's Avatar
I would first check that ECU. Are you sure it's a P13?
Is the check engine light on?
Old Oct 3, 2002 | 05:15 AM
EBP Lude's Avatar
was the engine fully warmed up b4 u revved it so high? Insufficient oil psi causes the engine to cut off its redline early!
Old Oct 3, 2002 | 06:30 AM
577HondaPrelude's Avatar
Default Re: how come my h22a revs out at 6500 rpm???? (EBP Lude)
Yup, VTEC will not work and your rev limiter should be at 6500 when U have low oil pressure.
Old Oct 3, 2002 | 06:36 AM
piotrush's Avatar
Default Re: how come my h22a revs out at 6500 rpm???? (57STS)
57STS - how do you like the 0w30 oil? does it drive any smoother?
Old Oct 3, 2002 | 06:40 AM
prelude1897's Avatar
Default Re: how come my h22a revs out at 6500 rpm???? (piotrush)
Go back and check your wire harness. Make sure everything is plugged in and you're not missing any plugs that go into the harness.
Old Oct 3, 2002 | 07:06 AM
Default Re: how come my h22a revs out at 6500 rpm???? (prelude1897)
0W oil is thinner than most so in theory it should run smooth, however I can't really compare to other oils because that is all I have ever had in the car from day 1. The oil is not too thin that it burn off, so it works great for me. Amsiol is great oil (the best IMO)
[Modified by 57STS, 11:07 AM 10/3/2002]
Old Oct 3, 2002 | 07:25 AM
2point6's Avatar
Surely, there is a check engine light on. pull the code finde out what it is. If there is no light on there could be an oiling issue.
Old Oct 4, 2002 | 01:10 AM
Acclude's Avatar
Default Re: how come my h22a revs out at 6500 rpm???? (2point6)
theres no engine light wot p13 n how do i fix it wot should the oil pressure b??
dxcivic121
Nov 25, 2012 01:07 PM
nelsond
Dec 4, 2006 12:22 PM
spurge
Feb 9, 2006 05:45 PM
Daily Interlude
Dec 3, 2004 12:11 PM
Acclude
Dec 2, 2002 12:46 PM
