White smoke on start sometimes
Old Oct 3, 2002 | 12:52 AM
snoop_bealybob's Avatar
Default White smoke on start sometimes
Sometimes after my 86 Accord (standard trannie) 213k miles,has been sitting there is white smoke upon starting. Goes away and doesn't blow white while driving. Doesn't loose coolant, doesn't overheat. My first thought was Head gasket . But it never happens when car is warm, and exhibits no other signs. Could it be valve stem seals ...maybe? Getting ready to pull the plugs tomorow to inspect and drain coolant/change oil. Thanks in advance.
[Modified by snoop_bealybob, 9:53 AM 10/3/2002]
Old Oct 3, 2002 | 01:30 AM
89_LXi's Avatar
Default Re: White smoke on start sometimes (snoop_bealybob)
Probably worn valve seals. If you do a compression test, that will tell you if it's a headgasket or not. Mine used to have a tiny tiny amount of smoke on startup (only on really cold days it seemed). When I did the headgasket, I had a valve job done with new valve seals and all, and they replaced 1 valve guide as well. Haven't seen one bit of smoke since
Old Oct 5, 2002 | 10:16 AM
iam7head's Avatar
Default Re: White smoke on start sometimes (89_LXi)
white smoke=bad! oil burning
Black SMog like smoke=rich fuelkay
that's what i heard ...
Notmyusername
Nov 15, 2018 05:11 PM
osiris22
May 16, 2011 05:31 PM
cars101
20
May 6, 2007 02:38 PM
aaaabbbb
Nov 3, 2004 07:23 PM
SSR'd
Feb 8, 2004 05:46 AM
