Dropping AC into a DX
Okay, I've searched for a bit, and I can't find any write up on how to install AC into a DX that never came without it. Its been a hot summer, and I'm just now breaking down to install it. I have a AC core, condenser, and compressor.... What else do I need and how straight forward is it? Thanks in advance.
The entire black box under the dash with the lines coming out, probably will need a new accumulator, dryer, ac wiring harness, ac switch for climate control. Make sure the ac lines you grab match the compressor you get. They have 2 different styles and the lines and compressors, varying depending on which compressor you get.
Any write ups you're aware of? Or is it simple enough I should t need one... I just don't have too much time the next week and don't want to do half then hit a road block or something
