Where do these hoses go? Gurus come this way PCV OIL COOLER TB
Welp trying to put this motor in and what not and having some troubles with all these ports and what not coming off the block. Im going to post some pictures of what im asking for if you need more pictures or something ill snap them asap. The motor is a b16 btw
First off what is the outlet next to the oil filter and where does it hook into? And is it ok if i just loop this oil cooler together like so?
Ok on my throttle body their is a hose coming off the bottom.. does this hose go to this 3rd smaller outlet off my thermostat housing.
That third outlet off the tstat housing does it go to the TB or somewhere else?
Also can i just run the pcv nipple up to the valve cover outlet?
Thanks never had to start out with something like this
SkoundrelUSA
15
Oct 31, 2006 06:27 PM
Tad
13
Dec 7, 2004 02:46 PM
Benjamin Tang
Nov 5, 2001 04:48 AM
