Could I have the wrong TPS?
Old Aug 5, 2011 | 09:20 AM
gorsey's Avatar
Default Could I have the wrong TPS?
I bought a new tps and stupidly binned the old one as it was damaged.
I've fitted the new one and seems to be correct however i'm adjusting it to the correct voltage .45 closed and 5 open. I have to turn the TPS beyond the screw holes to get it to read .45. If bolted on it reads way below .45. The TPS reads .02 if its fully closed.
Are there multiple types of TPS for the B16A? Or does the throttle need to be adjusted as well? If i open the throttle a few degree's i can get the TPS to read .45 and the bolt holes to match up.
confused!!
Old Aug 5, 2011 | 09:46 AM
civickiller's Avatar
Default Re: Could I have the wrong TPS?
i believe WOT is 4.5 and .5 closed
no multiple types
Old Aug 5, 2011 | 10:14 AM
OGGONZALEZ's Avatar
maybe the brand
gorsey's Avatar
no multiple types
Okay so that would mean the closed throttle position would need adjusting. Can that be done?
Old Aug 5, 2011 | 10:48 AM
HondaPartsHero's Avatar
Technical Hero
Are you making sure the plastic "prong" of the TPS is going between the brass "prongs" of the TB
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Old Aug 5, 2011 | 03:52 PM
gorsey's Avatar
Wow thanks for the pic. speaks a million words when you cant see down the back of the TB. hopefully i have it on the wrong side of it causing it to be out.
Old Aug 5, 2011 | 04:02 PM
remember the idea is to get the tps within those grooves, so what if the bolt hole dont line up at first, you can turn the sensor to match the bolt holes after
tb gaskets are pretty cheap, you can save the gasket with a razor
Old Aug 6, 2011 | 01:44 AM
gorsey's Avatar
sweet, that fixed my problem! simple lol. many thanks
Old Aug 6, 2011 | 05:16 AM
Technical Hero
updated pic for future thread clarification, glad it worked out for you
portenio78
Engine Management and Tuning
Sep 2, 2012 11:52 AM
TheSav
Apr 10, 2006 11:23 PM
b18cEK
Apr 4, 2006 04:09 PM
Used2beAb16
Jul 1, 2004 06:34 PM
evo
Apr 9, 2002 09:39 PM
