I need a few things cleared up about ECU tuning
This isn't a realm I have crossed over to. I have never had my own laptop or anything. So let me get this straight, you download Crome and then plug the computer into the wiring harness for the ECU and set the ROM numbers according to my personal preference? Where do I get the cable to run from a computer to the OBD1?
you need to chip your ecu first or buy hondadata ecu or any other product that allow you to change your fuel maps, I guess that is what you after
there is some info about chipping one of honda ecus
https://honda-tech.com/forums/engine-management-tuning-124/diymike-how-chip-your-own-ecu-2391816/
and there
http://www.************.com/forums/s...d.php?t=244832
parts needed you can get from here
http://www.moates.net/honda1-honda-e...-kit-p-42.html of course there is many different with ready sets like this one
good luck
ps use google next time, there is plenty info on it
and there
good luck
no not true, need to add a chip kit and vtec kit if you want vtec
cable from laptop to ecu is either datalogging cables or ostrich or hondata
lots of info. I did hours and hours of reading even made alittle notebook with my notes before i even attempted to tune my car. i was so nervous tuning my first turbo car
hondata uses a wire, samething with ostrich's to connect to ecu. if your running a chip, you burn the chip using the chip burner and put it in the ecu,
So as far as the actual tuning goes, that is where plugging in the laptop comes into play; to read how it is running? I might actually do this, seems like it would be pretty worth the money and effort.
It's not as easy as it sounds or as hard as it may seem, but if you don't know what you're doing you'll blow **** up.
Take EFI 101 if you're serious.
