B16a Idle issue
Old Aug 4, 2011 | 11:33 PM
jsg1990's Avatar
Default B16a Idle issue
Ok im going to give you all the full discription. I have a 1990 honda crx si with a b16a that is having a idle problem. I just put a new valve cover gasket ond new plugs in it. It was running fine before that and was running good for a little while after that. Can you please help.
Old Aug 4, 2011 | 11:41 PM
civickiller's Avatar
Default Re: B16a Idle issue
what kind of idle problems?
Old Aug 5, 2011 | 12:09 AM
jsg1990's Avatar
The Idle Fluctuates up and down a little no codes throwing on ecu.
Old Aug 5, 2011 | 12:16 AM
screw fitv in
take off iacv and clean it
im forgetting 1 other thing u can do
Old Aug 5, 2011 | 12:21 AM
jsg1990's Avatar
Thanks I will try that tommorow and I will post to let yall know if it works
Old Aug 5, 2011 | 04:31 PM
jsg1990's Avatar
Ok thanks dude problem solved thanks.
Old Aug 5, 2011 | 04:32 PM
jsg1990's Avatar
Another ? I have another crx si with a zc non vtec I am having a problem with it also.
Old Aug 5, 2011 | 04:35 PM
jsg1990's Avatar
When car is running you can pull spark wires and 1 3 & 4 boggs the motoe down but when you pull # 2 the car kills Any sougestions on what that could be.
Dirtyda8
Sep 27, 2018 04:40 PM
o0o_tylor_o0o
10
Mar 6, 2009 10:06 AM
hondachris1994
Feb 20, 2006 07:14 PM
WONG FRIED RICE
14
Sep 17, 2001 07:44 AM
