H22A EK hatch.
I am going to be putting a H22A into a EK hatch. Just wondering what what ecu would I be better off with? And what engine wiring harness should I use? Or does that matter as long as it's VTEC harness? I'm still learning and I intend to learn a lot from this.. so all the helpful info I could get would be great.
You need the EK hatch wiring harness. Just extend the wires, add wires for IABs, trim the injectors so your clips will fit on, it's pretty simple. And you need an OBD2 H22A ECU, or convert to OBD1 and run a chipped ECU
Good luck!
Okay great. Thanks. Now I have a question about injectors. Peak and hold vs saturated. Peak and hold require a resistor box.. correct? Are there certain resistor boxes for certain injectors or can it be any resistor box? I've looked everywhere and cannot find the answer to that question so I can only assume it's a dumb question. xD But I'd still like to know..
ryanlegros
Dec 31, 2012 06:11 AM
h22hatch88
Feb 27, 2008 01:35 AM
wbb6
Apr 9, 2002 05:11 PM
