Vtec Problems. (Bog, Lack of Power, Superloud)
Old Aug 4, 2011 | 09:40 PM
MyDeeCee2's Avatar
Icon6 Vtec Problems. (Bog, Lack of Power, Superloud)
ok so i have a 97 ls with a 98 Type R swap. the car does something really funny. the low end power of the car is VERY good but when it hits Vtec it hits reallly loud .. louder than normal hondas but the car seems to loser power. ive read other post about this but i never really got an answer. some ppl say its back pressure from a clogged cat? i have a cat and a stock ls muffler. and other people says it can be something with air flow?? my TPS is kinda messed up. it doesnt hook in all the way. it kind of just slides out. compression was good. my fuel pressure was low at like 44 but it was boosted to 56. so what do you think it can be? it also tends to bog sometimes when it hits vtec.. its really annoying because i dont know what it is
Old Aug 4, 2011 | 11:32 PM
civickiller's Avatar
Default Re: Vtec Problems. (Bog, Lack of Power, Superloud)
what ecu you running?
Old Aug 5, 2011 | 12:46 AM
MyDeeCee2's Avatar
jdm p73
Old Aug 5, 2011 | 01:07 AM
MyDeeCee2's Avatar
the motor is Jdm too by the way
Old Aug 6, 2011 | 08:13 AM
exb18c1's Avatar
Be sure that the PCM is stock.The 44psi pressure is the correct fuel pressure.What is the reason to go higher?Be more specific on the trouble.When is it happening?On the VTEC or not?How is the engine vacuum?
Post up
Old Aug 6, 2011 | 08:24 AM
mouab18c1's Avatar
How is your TPS messed up? CEL?
Old Aug 6, 2011 | 08:57 AM
MyDeeCee2's Avatar
Post up
ya when it hits vtec. right about after 5600 it just losses power and it starts to bog. but it is REALLY loud
Old Aug 6, 2011 | 08:58 AM
MyDeeCee2's Avatar
the wires are kinda worn. and one looks it its kind of stripped
Old Aug 6, 2011 | 10:08 AM
exb18c1's Avatar
Before anything the wire should be fixed and properly,no ducktape.Do you have any codes?
Old Aug 6, 2011 | 10:13 AM
exb18c1's Avatar
It will be great if you could connect a vacuum guage and rev the motor to the VTEC engagement point.At the same time you will eliminate the blocked cat.conv..
Old Aug 6, 2011 | 01:00 PM
you turned the fuel pressure up to 56psi?
should be 42psi w/ vacuum disconnected
Old Aug 10, 2011 | 06:12 PM
MyDeeCee2's Avatar
nope its not throwing any codes :/ im about to do a cat delete. ill let you know what happens after this
Old Aug 11, 2011 | 05:18 PM
MyDeeCee2's Avatar
bump
revhardEK
12
Oct 17, 2009 11:59 AM
Inextricabledrvr
May 1, 2007 03:36 AM
patchez
Apr 4, 2005 02:53 AM
ensracer
Mar 29, 2004 08:30 PM
NoLipRacen
Feb 27, 2004 11:24 AM
