heat problem
Old Aug 4, 2011 | 06:47 PM
tbuck23's Avatar
Default heat problem
Ok this is going to be a crazy question, I have a 95 honda civic ex with the d-15 sohc and the inside of the car get pretty hot I change out the Thermostat to see if that may help but no I have clue what else it could be any idea what it could be
Old Aug 5, 2011 | 09:00 AM
qpe's Avatar
qpe
Default Re: heat problem
my friend had similar problem, it wasn't getting extremely hot but still, his gear shifter cover and close to it area was getting pretty hot
the problem was lack of metal bit isolating the exhaust from the car's floor
it might be something different in your case
chill bro
Old Aug 5, 2011 | 09:25 AM
tobebadtaz's Avatar
where does the heat come from, and what is ur definition of hot?
Old Aug 5, 2011 | 11:16 AM
tbuck23's Avatar
were u are sweating your butt off
Old Aug 6, 2011 | 08:03 AM
exb18c1's Avatar
Check if the heat is coming from the air ducts.It's easy to check,just start and worm up the car and try to work the selector lever hot to cold and see if the air goes from hot to cold .Hondas use a valve to allow the coolant to pass through the heater core.You might have the valve stuck in open position or the control cable is broken or out of position.The selector lever should move freely.
Old Sep 3, 2011 | 08:06 AM
tbuck23's Avatar
that what autozone the valve is stuck open how can I get to it
Old Sep 3, 2011 | 08:19 AM
tbuck23's Avatar
my shifter do get hot come to thinking about it
Old Jun 23, 2012 | 06:31 PM
tbuck23's Avatar
Ok am having that same problem agian when i get into my car I can feel heat coming form somewhere.But i do have the heat off and all the vent close but i can't think where is coming from any help out there
kristi1989
Honda CR-V & Element
Dec 18, 2015 10:51 AM
KayTran
Dec 16, 2008 12:06 PM
odarkshineo
Honda Civic (2001 - 2005)
Jan 12, 2008 12:05 PM
