vtec help! vss help!
Ok... so have a 95 civic 4dr. Speedo is not working.. had original d15b7 in car didnt work, now swapped b18c in still not working. neither is my vtec. Will not engage at all... need help. saw on other postings that u need VSS for vtec. Have changed VSS, tried gauges, have power to gauges, still no speedometer.. odometer not working either... any solutions??? So... need help with Speedo to solve vtec problem any input?? thanks..
ok so checked wiring.. have continuity from VSS to the connector by the clutch cylinder. After that i dont.... so must be the wiring from connector to cluster... the color is yellow with a blue strip b4 connector and at cluster am i correct? thanks..
civicx
14
May 28, 2009 07:28 PM
