Window off track?
Old Aug 3, 2011 | 03:37 PM
boostedef123's Avatar
Default Window off track?
For almost a month and a half I havnt driven my car due to a broken ankle. Well to my suprise I get back into it today after letting my grandparents drive it. The thing is in horrible shape. Dings all around it. Ac seems to have quit working. And my favorite of all is what is messed up with my window now.
Here is a video of what its doing.
http://www.youtube.com/watch?v=DHMESzHAY00
It also wont close all the way.
Old Aug 3, 2011 | 05:17 PM
Default Re: Window off track?
Nobody has any idea?
Old Aug 3, 2011 | 06:35 PM
mtflyboy25's Avatar
ouch.. take it to a glass place...
Old Aug 3, 2011 | 07:05 PM
Sprockets's Avatar
This is common and happened to two of my Civics when almost brand new, as well as a friend's car. Take the door panel off, remove the speaker. Loosen the necessary bolts so that you can lube the track with Shin Etsu grease. I used rubber gloves and Q-tips to help lube the inside of the tracks. If you don't have access to Shin Etsu, just get silicone paste, not spray. If that doesn't work, you might need a new regulator.
Old Aug 3, 2011 | 07:33 PM
EJ8mike's Avatar
I had same exact problem not too long ago....I needed a new regulator, the teeth on the gear were rounded off. 30 bux at Advance.
Old Aug 3, 2011 | 09:09 PM
Are you sure it was just the regulator The reg and motor is 80 bucks I dont wanna have to spend that if i dont have to,
Old Aug 4, 2011 | 08:42 AM
EJ8mike's Avatar
yup just the regulator....if your window moves, then the motor is fine!
Old Aug 4, 2011 | 08:49 AM
hyperblu's Avatar
^^ this.
NightCat
11
Apr 18, 2009 03:05 PM
hotdoggies
Feb 19, 2006 10:03 AM
00ekcoupe
13
Aug 27, 2005 10:52 AM
Agent Zero
Aug 13, 2004 01:53 PM
n3v3tz
Feb 5, 2004 12:07 PM
