93 del sol ls swap - input needed on OBD2 to OBD1 conversion
Hello everyone, just bought a 93 del sol si, and an ls swap. The swap is obd2, what parts do i need to convert the swap to obd1, and to be able to drop it in the car? I will eventually be running lsv turbo, not sure if that helps.
Thanks,
Jayy
Thanks,
Jayy
Hey I got the Ls swap on my 93 Del Sol I'm in the proses of looking for a vtec head for the LSv and I also wanna boost it after that
Well me I got a B18a1 it use to be obd0 but now it's obd1 I took it to a shop to do the wiring I don't think they switched out sensors tho but hope to see the build soon
What year is the LS swap? If it's a 96-99, then you'll need an OBD2A Integra harness. If it's 00-01, then you'll need a OBD2B Integra harness. 100% plug and play. The OBD2 Integra harness splits at the shock towers just like your Del Sol. So you don't have to swap injectors, alternators, or distributors. Just plug in and go.
If your swap came with an engine harness, just use that and everything plugs in to the Sol's harness. Then just get your ecu chipped and put a stock progam on it.
The engine is from an 98 integra. The swap came with everything but a shift linkage, which wouldnt have helped me anyway. But motor, tranny, axels, half shaft, ecu harness, ect. everything was pulled from the same car.
Would i want to run the ls ecu? or a p06 for the time being?
So i will need an obd1 dizzy? And a friend of mine told me i could use the injectors that are on my z6 now, is that accurate?
He cant run the 98 ls ecu because it wont plug in directly without an adaptor. IMO it would be easier to just chip his P06 and call it good?
Drop the swap right in just as it was in the Integra, use a stock 94-95 LS ECU and your done. All you need is a del sol VTEC shift linkage.
kdoggparker
Oct 28, 2010 11:51 AM
