No hot start condition?
Old Aug 3, 2011 | 07:43 AM
jimmak85's Avatar
Default No hot start condition?
Hey guys I have a problem starting my 91 DX with a D15B2 after I've been driving for a lil bit and I shut it off and go to start it back up while it's still hot. It will just crank until the battery starts to die down then it will start. I'm also not sure that my battery should die down that quick either any idea?
Old Aug 3, 2011 | 09:09 AM
KINGVEM^^ED6's Avatar
Default Re: No hot start condition?
mine used to do this i pulled out the main relay and resoldered the points on the inside
or you can go to vatozone and buy a new one
Old Aug 3, 2011 | 11:00 AM
EfLunacy's Avatar
i would agree. Mine used to do that too. I think those main relays are pretty expensive for what they are. I re soldered mine. No problems since.
Old Aug 3, 2011 | 11:46 AM
jimmak85's Avatar
Thanks for the help guys how much does a main relay cost
Old Aug 3, 2011 | 11:49 AM
Donkey85's Avatar
about 45-55 bucks new or cheaper from a junk yard... the only thing about getting one from a JY is it could be in worse shape or equal shape to yours due to being the same age
Old Aug 3, 2011 | 02:08 PM
If u pull urs out and re solder it it will save u some chips
Old Aug 3, 2011 | 03:06 PM
jimmak85's Avatar
yea im good at soldering as long as it doesn't involve a circuit bored that's just too tedious so that's what i think ill do. thanks again guys
Old Aug 3, 2011 | 09:30 PM
FEAR6655's Avatar
The circuit board is not tedious at all, its pretty spacious.
Here is a picture of the board, and even points ou the joints that are most likely to have cracked:
76 camaro car
Dec 24, 2011 05:14 PM
turbodx95
Dec 13, 2007 07:12 AM
lrcrx90
Jul 3, 2006 03:14 PM
markchans
Dec 21, 2005 11:43 AM
junkyardRx
15
Apr 26, 2004 03:04 AM
