CEL Code 9 after z6 swap in 91 STD EF. All correction options unsuccessful. STUMPED!
Old Aug 2, 2011 | 06:31 PM
[Ennis_D]'s Avatar
Default CEL Code 9 after z6 swap in 91 STD EF. All correction options unsuccessful. STUMPED!
Quick run down:
- 91 STD EF hatch DPFI
- d16z6 swap w/ STOCK P28
- ConversionHarness.com OBD0-OBD1 DPFI-MPFI conversion harness
- wiring for DPFI-MPFI conversion, VTEC, CKP in dizzy, etc has been done and done correctly.
Got swap up and running and was getting CEL for 8 (TDC Sensor), 10 (IAT Sensor), 14 (IAC). Figured out my IAT was busted so I replaced it. Know I need a IAC as I have the classic idle problem from that. Here is where it gets funky:
I tried the first replacement dizzy to fix the TDC sensor problem I was having with the dizzy that came with the swap. "New", known-to-be-working dizzy was installed and at this point CEL Code 8 disappeared and CEL Code 9 (CYP Sensor) appeared. At that point I remove the CYP Sensor out of the original dizzy and swap it into the "known-to-be-working dizzy" and reinstall. Reset ECU, still get CEL Code 9. I then tried yet a THIRD good working dizzy and received the same results, CEL Code 9. I then tried the spare P28 I have and yet the same thing, CEL Code 9. I turned back to the second dizzy and it was at this point I figure a wiring problem on my part. I start with the OBD1 8-pin plug I swapped onto the OBD0 harness:
Pin #4 and #8 are the CYP pins for the dizzy that lead to the ECU. #4 Orange wire is the CYPP and #8 White wire is CYPG. #4 Orange leads to B11 and #8 White leads to B12 on OBD1 ECU. I have there position correct on the 8-pin dizzy plug ALONG WITH leading to correct pins at the P28.
According to the Helms manual, resistance between the Orange and White wire should be in the 350-700oHms range. My reading was 425 or so therefore I know the CYP sensor in the dizzy is in good working order. I then check continuity of the wires all the way back to the ECU. Continuity was good from dizzy plug to OBD0 ECU plugs, where they connect to conversion harness, where OBD1 ECU plugs are, and even IN the ECU itself telling me no broken wires from plug to computer. While I was at it, I also checked continuity of ALL dizzy wires on the 8-pin plug and ALL were good.
Here is where I am STUMPED! I have a CEL Code 9 with what appears to be a working CYP sensor in my dizzy. I have tested 2 different dizzys and 2 different P28s yielding the same results. I have tested the resistance between #4 and #8 on the 8-pin dizzy plug and my reading was within range according to the Helms manual, I have checked for continuity between #4 and #8 on the 8-pin dizzy plug and its good all the way into the ECU. All of this still yields a CEL Code 9 for CYP Sensor.
What in the HELL could be causing my CYP code? I feel that I have exhausted ALL options for correction and NOTHING has helped. I am turning to you guys for advice.
If you can help me, or give advice for things I may have missed, feel free to say so. I am not afraid to admit if I over-looked or forgot something as I know it will be a GREAT lesson learned for down the road.
TIA guys and I look forward to hearing replies!
Old Aug 4, 2011 | 01:36 PM
DCRB's Avatar
Default Re: CEL Code 9 after z6 swap in 91 STD EF. All correction options unsuccessful. STUMP
only thing that comes to mind is make sure there isn't any wires giving off an interference issue. have you tried running new, separate wires to the ecu from the dizzy for the cyp sensor? i had this issue when i was obd0 mpfi, everything checked out but still threw a code. however i was able to get another distributor and problem was solved. perhaps you just need a new or fully re manufactured distributor? is it possible the sensor was damaged when you removed it?
i have also heard of the bearing in a distributor going bad causing shaft play which will also throw this code. check shaft play on the dizzy as well
Old Aug 4, 2011 | 01:45 PM
[Ennis_D]'s Avatar
I have not ran a wire from ECU to dizzy but I have thought about that. I need to try it.
I would not think the sensor is damaged as it happened in the third trial dizzy as well. I can check the shaft play but I feel its either a wire problem or a mystery bug in the car being it came up in 2 different dizzies.
I greatly appreciate your feedback!
Old Aug 5, 2011 | 01:28 AM
DCRB's Avatar
no problem. I can't imagine how hard it was to figure out problems like these before the internet...
Old Sep 4, 2012 | 05:54 PM
[Ennis_D]'s Avatar
Okay guys, I am running a new "test wire" for the CYP+ tomorrow after work. I am going to quick splice it in place and IF it works, I will run and soldier the wire in place for a permanent fix. I am going to do the same thing for the IACV+ as well.
Any other input on the issue? Sorry to bring back a dead thread, I am just trying to get the car around to running correctly as I have a chance to trade it and would like it right for the other guy.
TIA!
Old Sep 21, 2012 | 06:59 AM
crx_si-r's Avatar
i see your problem already. your wiring for dizzy cyp+ (Orange) should be at ecu pin B10. not B11. and CYP- (white) at B12
Old Sep 23, 2012 | 12:50 PM
crx_si-r's Avatar
Any updates?
Old Apr 3, 2013 | 10:18 PM
Slvrwrx's Avatar
Originally Posted by crx_si-r
Any updates?
Isnt that the vss?
I have the exact same problem he has. I think youre incorrect.
[Ennis_D]
14
Apr 1, 2022 12:29 PM
D Grade
Aug 14, 2016 07:57 PM
EGk3nrock
Apr 27, 2007 06:59 AM
