Buy which jack? 20 inches high enough for jack stands?
Old Aug 2, 2011 | 01:35 PM
myhondatechacct's Avatar
Default Buy which jack? 20 inches high enough for jack stands?
Will a 20 inch high jack lift a 1992 civic's recommended front or rear jacking point high enough to put 11 inch jack stands under the car?
Rapid Pump® 2.5 Ton Heavy Duty Floor Jack,
$80
lift range:3-20 inches
Rapid Pump® 2 Ton Low Profile Heavy Duty Floor Jack
$110
lift range:2.5 - 23.75 inches
Rapid Pump® 3 Ton Heavy Duty Floor Jack,
$80
lift range:5-18 inches
Rapid Pump® 4 Ton Heavy Duty Floor Jack
$110
lift range:4-20.5 inches
Rapid Pump® 1.5 Ton Compact Aluminum Racing Jack
$70
lift range:3.25-14.75 inches
Rapid Pump® 1.5 Ton Lightweight Aluminum Racing Jack
$140
lift range:3.5-17.75 inches
http://www.harborfreight.com/automot...sc&order=price
Which should I get? People say heavier is better. I don't care if it's heavy. Any other considerations? Will a higher one let you do more different kinds of repairs?
Old Aug 2, 2011 | 01:44 PM
Str8EJ's Avatar
Default Re: Buy which jack? 20 inches high enough for jack stands?
n/m
Old Aug 2, 2011 | 01:46 PM
strategy400's Avatar
Originally Posted by Str8EJ
does this really belong in an 'all motor' forum?
I think it's a valid question seeing as you have to be able to safely jack the car to perform many of the operations discussed in this forum.
I think the 2nd one because 2 tons is plenty and the lift is the best there. $30-40 extra isn't that much when you're under the car and your jack won't go that extra inch.
Old Aug 2, 2011 | 01:49 PM
Medinabard's Avatar
i say the second is a solid choice more room to work is better
Old Aug 2, 2011 | 02:08 PM
Str8EJ's Avatar
plus it isn't in the 'all motor' forum.
my bad.
nevermind...carry on.
Old Aug 2, 2011 | 04:43 PM
Sprockets's Avatar
I'd get the second one. That must be a new model, because the previous one with the highest lift was an orange one, and I don't even see it listed. I sold my Matco clone, because it didn't lift high enough and had planned to buy a Ranger RFJ-3000LPF for $255 shipped:
http://www.asedeals.com/Ranger_floor_jacks.html
I think I'll just pick this one up instead. The design is very similar, and they're all Chinese anyway!
Old Aug 2, 2011 | 05:32 PM
HondaPartsHero's Avatar
Technical Hero
I have the compact aluminum and the 3 ton lightweight aluminum. I love the 3 ton because it is lightweight and also it jacks high enough to put jackstands under both sides. The compact aluminum you have to do one side at a time.
Old Aug 2, 2011 | 09:41 PM
NotAJDMFanBoy's Avatar
The 2nd one is probably the best. It all depends where you're jacking it up and where you're putting the jack stand. I usually jack mine up by the inner part of the LCA and put the jack under the jack point, or vice versa.
Lifting capacity should be the least of your concern. The cars are light.
Old Aug 2, 2011 | 10:01 PM
98civdx's Avatar
Master Detailer
I've got one of those low pro jacks from harbor freight.
I'd go for the second one. pretty low sadle height, but pretty good total height.
If mine were to lift just 1.5/2'' inches higher I'd love it.
Old Aug 2, 2011 | 10:06 PM
MoreCowbell's Avatar
I have the low purple HF one and normal stands which is not a good combo since I cannot raise the car high enough to land it on the normal height stands
Old Aug 2, 2011 | 10:39 PM
fleabag's Avatar
I like the Arcan Low profile jack which can go up to like 24 inches and has like 3.5tons of lifting capacity (more than enough) . Downside is that it's so heavy...
http://www.bimmerfest.com/forums/showthread.php?t=80476
Bought that Arcan at Costco for like $80...
The best part about buying a jack with lots of lift capacity is that when you lower a light car, there is less risk of the car just plopping down onto the jack stands, which can be damaged and potentially fail at the worst time. I remember reading reviews saying that the Arcan had problems with gently lowering the car but I had no issues slowly lowing a Toyota Tundra when I used mine and I think that's because I was lowering a relatively light vehicle... Again, I have to emphasize that this jack is not light but nonetheless is quite beefy!
As for Jackstands, I bought these which I think give a little extra peace of mind:
http://www.amazon.com/Torin-T46002A-Double-Locking-Jack/dp/B00026Z3DQ/ref=sr_1_1?s=automotive&ie=UTF8&qid=1312353533&sr= 1-1
Old Aug 4, 2011 | 05:20 AM
crisdawg's Avatar
You could always get a MaxJax (http://www.maxjaxusa.com/) like me, works GRRREAT! Though you would need a garage haha.
chippinpressure
Feb 26, 2011 06:26 PM
ahobbs
Feb 23, 2011 11:08 AM
k24killer
Aug 14, 2007 09:53 AM
Rob!
Oct 13, 2005 03:41 PM
veejay
Jul 22, 2001 10:57 AM
