Z10 Radius rod adjustment??
Old Oct 2, 2002 | 08:03 PM
b20civic's Avatar
Default Z10 Radius rod adjustment??
Does anyone know the best way to adjust my z10 engineering radius rods on my 92 hatch? What is a good base line to start with? How do other owners of the radius rods have yours adjusted? Im looking for the most straight line traction. Reason i bring this up, is because I was pulling 2.1 60fts quite often, now after i adjusted the rods much shorter, i am now only able to pull very high 2.2s to low 2.3s. Ive heard that having these adjusted properly is pretty important to good 60 ft times. thanks alot
ERIK
Old Oct 5, 2002 | 08:43 PM
visi0n's Avatar
Default Re: Z10 Radius rod adjustment?? (b20civic)
umm i think the adjustment goes the middle being when there is play in the rods. And for adjustments two full turns either way depending on how you want your car to react... I think it was anything more than 2 turns will result in need of an alignment being done because this will alter your toe
umm don't quote me or anything its been a while...
daigo
14
Jun 22, 2010 12:23 PM
johncarlos
May 1, 2004 02:51 AM
allmotorhonda
Dec 21, 2002 08:11 AM
Quetzolcotl
May 22, 2002 09:51 AM
sek311
Apr 26, 2002 04:56 PM
