b16a parts?
Old Oct 2, 2002 | 07:50 PM
-16V-'s Avatar
Default b16a parts?
whats up,
i'm rebuilding my b16a from the ground up and i want to buy a new starter and alternator and just woundering what year and model car to say its for at the auto part store?
94+ del sol vtec, or 90-91 integ?
Old Oct 2, 2002 | 09:45 PM
Chris's Avatar
Default Re: b16a parts? (1991_jdm_sleeper)
94+ del sol vtec
Old Oct 2, 2002 | 09:46 PM
Chris's Avatar
Default Re: b16a parts? (Chris)
more info...
If you can find an actual SIR (gold) shift linkage it will work with b16 crx. Well in mine it did. I have the XSI rear bracket, and Hasport billets! I wish I would have known before the swap though. I was stressing that I was going to have to have hasport fed ex me their shift linkage for $$$
Heres a replacement parts list for b16.
Part Honda # Source
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (with crank seal) 15100-PR3-024 94 - del sol
Oil Pump O ring (not with Pump) 91302-PF0-003 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Valve Cover Gasket 12341-PR3-000 94 - del sol
V-TEC solenoid valve filter O ring 15825-P08-005 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose (trim) need hose clamp 19501-PR3-000 92 - integra gsr
Lower Radiator Hose (trim) need hose clamp 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
I also have this list in excel format with dealer prices if anyone wants it. No one handed me this list down, but I wish I would of had it before starting the swap.
Monty (wreckedhatch)
WindyIce
17
Nov 16, 2015 05:42 AM
w-fuck-ay
Nov 17, 2003 06:29 AM
90hbvtec
Oct 31, 2003 10:08 AM
SeaBass
May 31, 2003 03:48 PM
Monty
Sep 7, 2002 05:41 AM
