96 Civic Transmission HELP!!!!
Old Oct 2, 2002 | 07:35 PM
ransack's Avatar
Default 96 Civic Transmission HELP!!!!
I'm replacing the clutch in the civic. I've to the point where the tranny SHOULD drop out, but nothing is happening. We've searched for all the bolts and so far we've got them all. Does anyone know a place that I can get pictures or skimatics of the tranny. i need to know if I need to take out anymore bolts
thanks
-Jesse
Old Oct 2, 2002 | 10:26 PM
1 speedstar's Avatar
Default Re: 96 Civic Transmission HELP!!!! (ransack)
don't forget the flywheel cover bolts, and if everything is off.. then try using a pry bar and peel the trans away. the trans may be difficult to take off b/c of the dowel alignment pins. good luck
Old Oct 3, 2002 | 07:49 AM
Chrislow's Avatar
Default Re: 96 Civic Transmission HELP!!!! (p r ! m o)
Don't forget the bolt that goes through the starter!!!
Old Oct 3, 2002 | 09:26 AM
ransack's Avatar
Default Re: 96 Civic Transmission HELP!!!! (Chrislow)
thanks guys
i got all the bolts I could see out yesterday. BUt it still didnt drop. Where is the starter bolt. im sure I took all of the bolts, but where would this one be
[Modified by ransack, 7:05 PM 10/3/2002]
Old Oct 3, 2002 | 03:45 PM
Chiovnidca's Avatar
One of the starter bolts goes all the way through to the engine block. You have to remove it.
Old Oct 3, 2002 | 06:07 PM
Mikey's Avatar
Default Re: 96 Civic Transmission HELP!!!! (Chiovnidca)
Check all bolts again..
[Modified by Mikey, 9:08 PM 10/3/2002]
Old Oct 3, 2002 | 08:56 PM
ransack's Avatar
Default Re: 96 Civic Transmission HELP!!!! (Mikey)
I got it off.
it was the starter bolt
that little motha was hiding
I got it all off
and on the process of putting it back on...I snapping a pressure plate bolt
hella sucks. im going to honda tommorrow to get some more. and get flywheel fixed
Old Oct 3, 2002 | 11:49 PM
2camsaam's Avatar
did you have a broken flywheel?
Old Oct 3, 2002 | 11:58 PM
ransack's Avatar
Default Re: 96 Civic Transmission HELP!!!! (2CAMSAAM)
no
but now I have a bolt stuck in it. I have to take to a machine shop and get it taken out
SIRIUS VTEC
Aug 24, 2010 10:49 AM
92EGMINIME
Apr 10, 2010 08:18 AM
SOFLSOL
Jul 5, 2009 03:23 PM
SOHC_MShue
Jul 27, 2004 07:29 AM
ransack
Oct 2, 2002 07:31 PM
