Sea foam ?
Old Jul 31, 2011 | 08:35 AM
jdmsir4dr's Avatar
Default Sea foam ?
Do you guys recommend using seafoam in the motor to clean it out some of the carbon etc..its a d16z6 with only 82xxx miles..i did search online but i only came across threads that are over 1 yr old
Old Jul 31, 2011 | 08:42 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Sea foam ?
I'm sure you didn't search hard at all. Someone just posted this last week. Screwed up his engine.
Old Jul 31, 2011 | 08:52 AM
jdmsir4dr's Avatar
Sorry I meant to say searched on goggle..I'm doing all this from my cheap phone lol....is there anything else u would use to clean it
Old Jul 31, 2011 | 09:28 AM
The Grumpiest
Why do you think it needs "cleaning"?
Old Jul 31, 2011 | 09:32 AM
Former User's Avatar
It should be safe to add Seafoam to the gas tank and through the brake booster vacuum hose. For the latter, replace the spark plugs afterwards. Adding to the crankcase is a matter of choice, but I think that it's also probably okay for an engine with 80K miles as long as you follow the directions.
Old Jul 31, 2011 | 09:36 AM
redm3turbo's Avatar
I know 30-40 people personally that have used seafoam to clean their engines, never did any harm.
Most do it through the brake booster vac hose, and then watch the huge white smoke clouds----and believe they just cleaned their engine out..
Im not convinced it does anything--- although 90% of the people I know say they feel an immediate difference.
Id say try it.....and see how it goes. As far as I know, its completely safe (as long as you follow the directions)
Old Jul 31, 2011 | 09:55 AM
Hidenplanvew's Avatar
BG44k
Old Jul 31, 2011 | 10:20 AM
hyperblu's Avatar
Originally Posted by Hidenplanvew
BG44k
^^ useless post... Obvious troll is obvious.
Old Jul 31, 2011 | 01:02 PM
milkwasabadidea's Avatar
what do you guys think about sea foam spray?.. not the deep creep lube... but the cleaning one.... that sprays into the throttle body.
Old Jul 31, 2011 | 01:25 PM
hyperblu's Avatar
Im sure it's the same stuff only in an aerosol can...
Old Jul 31, 2011 | 02:49 PM
BG44K is the best stuff you can have in your system... seafoam is what 8 bucks or something BG is 25 bucks a can... I have seen Bg44k Actually make a car pass Emissions aloneand increase mpg in a 20 year old V8
Also BG backs there product so if it harms your engine they correct it... Sea foam dosent
Troll??
Old Jul 31, 2011 | 03:57 PM
visormurp's Avatar
BG44K is what was recommended to me by my local Honda dealership. I didn't buy it there because I was skeptical but I've used it many times over the years and like the results.
Old Jul 31, 2011 | 05:00 PM
Slacker93eg's Avatar
10 Year Member
I'll tell you yes yes yes. Seafoam is jesus juice for motors, does an amazing job. Especially if you do it right and put it on a dripper and let idle for 30 min.
Old Jul 31, 2011 | 05:05 PM
BoostedBees's Avatar
Agreed done this a few times already without any problems
Old Jul 31, 2011 | 05:06 PM
jdmsir4dr's Avatar
So i guess ill give it a shot n try BG44k
Old Aug 1, 2011 | 03:03 AM
hondamark35's Avatar
just to add a bit more to the list of replies...
when used properly, Sea Foam can work. there was no appreciable effect in my civic, but my wife's accord was like a different car after running it through. it must have been dirtier.
Old Aug 1, 2011 | 05:38 AM
turbodcxbro's Avatar
SeaFoam works great if used correctly, those idiots that have messed something up using it had other problems or were just plain stupid. I've used it dozens of times and my old man does as well at his shop with never a single complaint or problem.
Old Aug 1, 2011 | 05:47 AM
The Grumpiest
https://honda-tech.com/forums/showth...light=Sea+foam
Old Aug 26, 2014 | 10:47 AM
Fante's Avatar
I recommend it.
Old Aug 26, 2014 | 11:22 AM
NotARaCist's Avatar
I never narc'd on nobody!
And ya know what no one here recommends? Bumping a 3 year old, dead thread. Don't do that. Ever.
Old Aug 26, 2014 | 01:06 PM
EsotericImage's Avatar
Retired Moderator
/thread
RACEPAK
Welding / Fabrication
Apr 27, 2015 06:17 AM
milkwasabadidea
Aug 29, 2011 05:14 PM
Discontained
Oct 25, 2006 03:16 PM
FortunateFool.
Jun 15, 2005 05:56 AM
