Bubbly rad neck, loosing coolant, but no white smoke?
Old Jul 29, 2011 | 05:35 PM
Canadian_EF's Avatar
Default Bubbly rad neck, loosing coolant, but no white smoke?
Swapped in a d16y8 running obd1 p28
runs fine. was going down the highway today at 4k (Si transmission), temp started to rise to half way.
checked fitv (i think, it's a 2 wire big sensor connected to back of intake)
top bolt was loose, tightened it. one hose was a little wet.
stopped for a few mins, took the same trip a little slower (3-3.5k), no issue.
rad filler neck still bubbles after 10-15mins running. coolant level lowers. overflow bottle is filled past full (wasn't when i refilled my rad last)
bad head gasket? bad thermostat? no white smoke, so i'm not really sure. can smell coolant in the engine bay tho, can't find a visible leak!!!
any insight is appreciated.
(also the footwell is always warm, not sure if that has to do with this or not)
Old Jul 29, 2011 | 06:51 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Bubbly rad neck, loosing coolant, but no white smoke?
Do a leak-down test and that will help pinpoint your problem. May as well compression test it too while you are at it to see the shape of the combustion area.
Ozne99
May 27, 2008 08:36 PM
Prudz_lude
Apr 22, 2007 08:42 PM
Driven
11
Oct 29, 2004 11:41 AM
EdBoon
Dec 17, 2003 05:24 PM
t616
Jun 21, 2003 02:35 PM
