Vtec not working; b18c swap
Ok well today I took my eg out for the first time since the new motor was put in. I decided to get on it, its really quick but you can tell the vtec isn't engaging, i even tried slowly accelerating from 1st and i could tell it doesn't work. I have a cel on but its for the CKP and its an obd2 swap into my obd1 eg. i am using a p28 ecu, its using a b16 chip right now. Any thoughts of why it isn''t working?
Well i took it off, and checked it a few times, i re soldered everything to make sure it was good and connected. I have no idea what else it could be, I took a multimeter to it and there was no current running to the vtec solenoid.
Edit: You will need a USDM VTEC solenoid with the pressure switch not unless you disable it from the ECU.
Nah i have no idea how to fix that. I checked the wiring and everything though, i made sure i converted the dizzy right and everything. That light will not go away though...
Well i can't just find one randomly, I don't have any way of just getting one, unless a friend of mine let me borrow theres. But i doubt they will. But I am not throwing a code for the vtec, ill check again to make sure though.
I have never done this but I have heard of testing the solenoid by running a power wire to manually test the functionality. again never done it....I just have extra solenoids to test thank goodness.
Are you using the solenoid from the JDM ITR?
UPDATE: Fixed it, for some reason the harness had the pressure sensor wires backwards, the green was on the ground wire, and the black was on the blue wire. So i wired up the black to the solenoid and grounded the green wire. Went out and drove it, Vtec hits hard. No more CEL either. Thanks for the help.
Yeah i know... i will I'm waiting for my friend to get up so we can make one. And its a y21 trans, but it has s80 with LSD gearing i believe. It was on my b16 at first, then i just stuck it on the b18c cause i didn't wanna buy another trans when i already have one with a lsd.
deewaynex757
May 22, 2012 04:50 PM
ringgold
Oct 21, 2004 07:15 AM
