What should we do next to the car?
This is the car that won first place in the JDM class at Import Expo 3 in Houston. Just thought we'd get some input on what we can do to better the car for future events. I'll be happy to answer any questions anyone may have. Oh, and keep in mind this car is also going to be a turbocharged road race car. So any engine, suspension, etc. setup suggestions would be greatly appreciated. Thanks in advance.
i find it hard to beleive you did all that to the car but yet you still dont know what to do next!
you would think you had a plan after all the work and money in that car
i find it hard to beleive you did all that to the car but yet you still dont know what to do next! you would think you had a plan after all the work and money in that car
good looking car. If your going to be road racing then the best thing to do is twek all the suspenson stuff first. I looks like you have the good motor. put some good tires on it.
for that car to win a jdm contest i bet it didnt have much competition it dosnt look to jdm to me
the yellow eg looks cleaner than that car id vote for the eg plus the ek looks like it has sinkos on it
[Modified by One Honda, 2:33 AM 10/3/2002]
Anyway, I would say suspension and brakes (i can't really tell what going on there).
well it looks great so far,about what to do to it next i don't know wny mess with perfection also what wheels are those,are they rnr's
Like JDM? Maybe this one can give you guys some ideas...
Talk about top of the shelf products...
But yeh, nice ek, the cf bumper looks a bit weird tho...
Specifications
Car Base 1998 Honda Civic EK4
Engine 1996 B18CR
Displacement 1820cc
Max Power TBA
Max Torque TBA
Compression Ratio 9:1
Engine Oil Castrol 10W-60
Turbo HKS GT3240 56T A/R 0.63
Intercooler Trust 12"x24"x4.5"
Blow Off Valve Trust Type-R
Wastegate Trust Type-C 50mm
Engive Sleeves Darton Wet Type
Boost Control Blitz SBC-DC
Injectors 720cc x 4
Traction Bar Z10
Main ECU Apexi Power-FC
Camshaft Jun VTEC Cam Type-III
Valve Spring Jun Double Spring
Sprocket Spoon Cam Sprocket
Pistons JE Forged 81.5mm
Connecting Rods Crower
Crank Shaft Spoon
Retainer Jun Titanium
Oil Pump Spoon
Oil Catch Tank Trust
Ignition MSD Digital 6 Plus
Spark Plugs HKS Plug S45I
Fuel Press, Regulator Apexi
Fuel Pump Holley 190LPH
Intake / Exhaust / DRIVE TRAIN
Air Filter HKS SPF
Intake Pipe Custom Made 3"
Muffler Kakimoto-R (76.2mm)
Clutch Tilton Twin Plate
Flywheel Custom 3.8kg Forged
LSD Kaaz 2-Way
SUSPENSION
Suspension Apexi
Damper Kit Apexi 2000 Pro Spec
Engine Mount Mugen
Strut Tower Bar Cusco
Crossroll Bar Do Luck
Lower Arm Bar Spoon
Wheels Advan RG 17x7.5JJ (+45)
Tyres Bridgestone S02 215/40/17
Brake Pads Endless NA-S
Brake Rotors Zeal Straight-6
Brake Calipers Spoon 4-Pot
AERO
Front Bumper Buddy Club
Front Lip Buddy Club
Side Skirt Buddy Club
Rear Wing Buddy Club
Rear Under Lip Buddy Club
Rear Bumper Buddy Club
CF Bonnet Monster Sport Japan with Air Duct (4kg)
Other
Body Colour White
Gauges Trust Warning Meter
Blitz DC 2.0 Boost Gauge
Seats Recaro SR III
Oil Pan Spoon
Oil Cooler Trust
[Modified by EG6-SiR, 2:48 AM 10/3/2002]
Specifications
Engine 1996 B18CR
Displacement 1820cc
Max Power TBA
Max Torque TBA
Injectors 720cc x 4
Traction Bar Z10
Crank Shaft Spoon
Oil Pump Spoon
Air Filter HKS SPF
LSD Kaaz 2-Way
SUSPENSION
Suspension Apexi
Engine Mount Mugen
Lower Arm Bar Spoon
AERO
Other
Body Colour White
Seats Recaro SR III
Oil Pan Spoon
Oil Cooler Trust
Glad you like the car. I've done a bunch of stuff to the suspension already. Cusco rear strut bar, Cusco rear lower tie bar, factory Honda front strut bar, ST sway bars Fr & Rr, Do-Luck interior brace bar, Skunkworks Coilovers on Tokico blues. Tried to fit on a Cusco, Tanabe, etc. front lower tie bar but none clear the 4 into 1 header. Next on the list is an 8 point rollcage (welded in), JIC coilovers, Cusco C-pillar tie bar, and ES bushings. I have Falken Azenis tires by the way.
They are not Sinkos. They are RNRs that we had powder coated bronze. We did the same with the valve cover and front strut bar. Oh yeah and we have CTR moldings. We didn't paint them so they'd match the kit, interior, and side mirrors.
Turbo for road racing?? Well, I dunno what type of road racing you are referring to, but a turbo wouldn't be that great for road racing unless it was a smaller turbo. I know you couldn't be turbo if you were in the Honda Challenge. I would definetly not recommend a turbo for autox'ing, that would actually be worse! If you are planning to go in a straight line, I say get this biggest turbo you can, but if you want to road race stay the way you are or possibly look into getting a small 16G, but nothing larger..you wil regret it even if it was ball bearing.
Looks like you already have a nice engine, so here are the mods I would start for strictly road racing. (Again, I dunno what you have so bear with me):
Relocate the battery to the back, enclosing it in a approved vented box(Moroso)
Remote oil filter
oil cooler
JIC Majik or Tein suspension
26mm+ front sway bar
22mm+ rear sway bar(I like the Progress 25mm personally)
Z10 traction bars for the front
rear upper tie bars if you don't already have them
ITR master cylinder
disc brake upgrade for the back
larger calipers are more important than larger rotors IMO, even if the rotors were slotted. I would only get these(larger rotors) if the car was strictly a race car
various guages(water temp, oil temp, fuel pressure, and oil pressure would be my choice)
also think about getting a Wideband O2 for tuning
Thats about all I can think of for now, hope it helps!
[Modified by maxim, 9:12 PM 10/2/2002]
Remote oil filter
oil cooler
ITR master cylinder
im not feelin the CF bumper
the only advice i can give is, actually use the road race parts for their purpose from time to time, then you'll be ok
and even more unique alongside the other usual showcars
That car should have won best in class for unfinished paint job look, and fifteen different color scheme class. Whatever, these show guys...I'll never understand them.
