Oil in plugs?
Old Jul 27, 2011 | 01:03 PM
koulninja's Avatar
Default Oil in plugs?
There's oil in the spark plug, what does that mean? Headgasket leaking? Spark plug loose? I'm changing spark plugs and wires this weekend just wondering if theres anything i should be looking out for since theres oil leaking into the wire plug.
Old Jul 27, 2011 | 01:06 PM
Former User's Avatar
Default Re: Oil in plugs?
You need to replace the oil seals in the valve cover where the spark plug tubes insert.
Old Jul 27, 2011 | 01:21 PM
koulninja's Avatar
Is this it? #7
https://www.hondapartsunlimited.com/...20HEAD%20COVER
Old Jul 27, 2011 | 01:30 PM
BlackCivicEX's Avatar
what jon said, i had same issue, bought a new valve cover gasket set for 40 bucks. No problem since.
Old Jul 27, 2011 | 01:38 PM
EL Vap133's Avatar
Originally Posted by koulninja
That is it!
Old Jul 27, 2011 | 02:14 PM
koulninja's Avatar
Thanks! Gonna order it.
Old Jul 27, 2011 | 03:51 PM
motegicivic's Avatar
Make sure you get the valve cover gasket and the spark plug tube gaskets, I am not sure if you can get it as a set or not.
Old Jul 27, 2011 | 05:22 PM
redm3turbo's Avatar
yea...make sure you also change the valve cover gasket (with a dab of RTV) so you arent leaking from there also.
O rings on the spark plug tube is a 10 min job....super easy...
Old Aug 1, 2011 | 06:44 PM
xreaverx's Avatar
yeah, the 12030 numbers are sets of (valve cover gasket, upper spark plug tube seals, and valve cover grommets)
though if there's no oil seepage at the top of the spark plug, you may have to replace the LOWER tube seals as well
91302-PJ7-003 [x1]
91301-PJ7-000 [x3]
but you've gotta remove the valvetrain, and do a valve adjustment for that.
Old Aug 1, 2011 | 08:23 PM
dc2low's Avatar
just use a whole new valve cover gasket set, its never worth doing halfass
Old Aug 1, 2011 | 08:24 PM
CivicBlacksheep's Avatar
10 Year Member
^valve cover gasket kit
Old Aug 1, 2011 | 08:42 PM
NAEK HATCH's Avatar
yea man i had the same issue about a week ago. autozone has just what you need and you will be all good. the plugs should be at 20lbs. it seems more then i thought but thats what my book says.
Old Aug 1, 2011 | 08:51 PM
Spark plugs?
From the service manual:
foxfai
Mar 31, 2009 08:03 AM
skaternak
Oct 2, 2008 10:32 PM
matryx
Dec 15, 2007 01:18 PM
square_1
Jul 21, 2006 11:14 PM
OBDI JEDI
Jun 3, 2003 09:33 AM
