2005 Honda Civic EX Over heating problem - Need Help
Hello everyone,
I've been having some over heating problems for about 3 weeks now and can't seem to figure out the problem.
Here's a short video that I recorded so you can see what the car is doing.
Link: http://youtu.be/iLiJsSItkj4?t=13s
Short recap, the car over heats when idling and sometimes while driving at low rpms, but when I accelerate and put the engine at 3k rpms it goes back down.
Things that I've tried already:
Flushed entire system
Bleed air out
Checked fans, both fans are working at full speed
Changed water pump (it was making a squeaking noise)
Radiator compression test, no leaks
Checked and changed spark plugs but old spark plugs were fine.
Replaced Thermostat
At this point I'm not sure what to do anymore, any help will be greatly appreciated.
Thanks in advance,
Alex
Bleed air out
Replaced Thermostat
Thanks in advance,
Alex
