B18b with YS1 Trans Axle Question
I'm dropping a B18b with a YS1 cable trans into a 94 DX and I'm having trouble finding a straight answer on what axles to use. Can I use 94+ Integra axles or do I need 90-93?
You can use either type of axles.
If you use '94-'01 Integra axles, you will also need a '94-'01 intermediate (half) shaft.
If you use '90-'93 Integra axles, you will also need a '90-'93 intermediate (half) shaft.
to add to what Mcvtec said make sure that whichever intermediate shaft you use you use the axle seal that goes with it, failure to do so will result in a massive oil leak.
hasport makes a set of mounts, as well as a couple of other companies, you'd really be a lot better off buying a hydraulic tranny though, or even a case, YS1 guts will swap over.
JJ-Built
Jan 2, 2002 08:27 AM
