Car Starts but wont move, wierd idle
Just did a 0db1gsr swap into a 98 ek, using a conversion harness and a chipped p28 ecu.
The car starts after a while of cranking it and idles weird. First it would go to 2000 rpm then 0 like its bout to die, it does this for about the first 2-3 mins when started, then it stays at 1500 rpm to warm up. whenever its given gas, it would die(or almost), plus it wont move an inch! Its getting gas so am thinking its a problem with the intake manifold.
I was getting three codes which are 14, 7, 3
I was told that it could be the throttle body so i got that changed with new sensors but it does the same thing. Am planning to clean the IACV next
Anyone experienced anything like this. I want to have an idea of what am dealing with.
smokinloc
Mar 8, 2010 01:39 PM
