Up pipe/hood exit
Old Jul 25, 2011 | 04:52 PM
hello1320's Avatar
Default Up pipe/hood exit
Has anyone tried/ used an aluminum pipe ?
If so how did it work out
Old Jul 25, 2011 | 05:02 PM
MrParks's Avatar
Default Re: Up pipe/hood exit
use aluminum. i havent seen no difference. just have to use 14g or thicker.
Old Jul 25, 2011 | 05:08 PM
Desir Performance's Avatar
The only benefit I would see using aluminum as a down pipe would be for the weight factor, but a up pipe is so short it wouldn't in my opinion justify the price difference from stainless steel.
Old Jul 25, 2011 | 05:30 PM
Blown90hatcH's Avatar
Not sure where you are getting your bends from but they are pretty much the same price from AL to SS.
Only issue I had on AL downpipe was the abuse from the 2-step.
Old Jul 25, 2011 | 05:50 PM
hello1320's Avatar
The pipe on there now is very short...the wideband doesnt read right so iam just gonna make a longer pipe..... ive actuall got some 14g alum bends so it should work out good. I would go down with the exhaust but its impossible with my setup...
Old Jul 25, 2011 | 08:01 PM
nonvtecallmotor's Avatar
The aluminum will start to sag at the bends from the heat if its not suppurted.
Old Jul 25, 2011 | 08:35 PM
rota92
Guest
Posts: n/a
Someone told me at some point over the years that a steel downpipe will help keep heat in the turbine longer instead of the aluminum helping to draw the heat away.
In my head it seems to hold true but like using a watercooled WG on a drag car, it just seems silly to do something expecting HP results after a burnout and WOT lol
Old Jul 25, 2011 | 08:50 PM
vtekthis's Avatar
i had a alum .120 wall up pipe, ended up the vband flange split from heat and vibes, also need to think that the wideband heater circuit is affected by the heat sink of a alum downpipe u have...i saw no difference but something to think about when making desision
Old Jul 26, 2011 | 06:00 AM
hello1320's Avatar
Thanks
Old Jul 26, 2011 | 06:42 AM
tony1's Avatar
By the time you make it .120 wall, is there really any weight savings to be had?
Old Jul 26, 2011 | 04:08 PM
vtekthis's Avatar
prolly weighs more lol, and u got to always look for cracks, that **** is for the birds, make it stainless and be done with it....
Old Jul 27, 2011 | 08:22 AM
ROMEO856's Avatar
other then saving some weight and maybe some clearance are their other benefits from a uppipe period? no one has ever really given me a good answer
Old Jul 27, 2011 | 05:21 PM
90blackcrx's Avatar
The best exhaust on a turbo setup is the shortest possible exhaust.
Martian's Avatar
You can see when your motor blows. I fire slotted 2 heads last year and my up pipe helped to keep me from putting a large length of water on the track.
Old Jul 27, 2011 | 06:42 PM
Totally agree with you guys there wouldn't be a up side to an AL up pipe, and like I said before the price difference from ss would be much higher when you factor in the thickness. Also the 02 bung would prob get a beating from taking the wide band in and out for tuning.
Old Jul 28, 2011 | 05:27 AM
90blackcrx's Avatar
You also have to worry about the scrap man trying to scrap it. They love themselves some aluminum pipe
Old Jul 28, 2011 | 01:39 PM
jdm inc's Avatar
i used ss for my up pipe.
Old Aug 2, 2011 | 05:58 PM
jpenman50's Avatar
They like to melt on antilag in some cases.
hondaapi
Welding / Fabrication
Jul 4, 2006 08:21 PM
r0yal
Apr 19, 2006 07:03 PM
FURACERMAN
Jan 6, 2006 06:32 PM
B16CRXT
Mar 14, 2005 02:34 PM
tonezilla
Feb 15, 2005 07:17 AM
