Rebuilt b18b1 smoking blue
Old Jul 25, 2011 | 01:34 PM
dallas306's Avatar
Default Rebuilt b18b1 smoking blue
Hi there: My newly built b18b1 seems to be running great but smokes quite a bit of blue. Engine is built for boost but is running all motor while im piecing together a turbo setup.
Specs are as follows:
-obd1 b18b1
-new oem pistons and rings
-acl bearings
-arp headstuds
-cometic head gasket
-clutchmasters fx300 clutch
-skunk 2 valve springs
-brian crower stage 2 turbo camshafts
-buddy club adjustable cam gears (set at 0)
I have approx 280km on the engine (170 miles)
It lightly smokes while warming up from a cold start but not as much idling once it has been driven a bit. If I have been sitting at a red light for a few minutes and then pull away I will notice a puff of blueish smoke as a pull away, and an oily exhaust smell.
All other seals and gaskets have been replaced (valve seals, valve cover, etc....) I followed a pretty aggresive break in procedure that a friend gave me (he has build many honda motors and broken them all in this way with no problems)
The odd part is I have not had to add oil at all. It is still reading full on the dipstick and doesnt seem to lose oil at all (or very little) but it's still smoking this way and im a little bit concerned.
If anybody has any idea's, theorys, or has experienced this. Let me know. Thanks
Old Jul 25, 2011 | 05:13 PM
frankenghia's Avatar
Default Re: Rebuilt b18b1 smoking blue
If your motor is built for boost you may be getting blow by at the rings. They may need the boost to seat correctly. Just a thought.
Old Jul 25, 2011 | 07:25 PM
civickiller's Avatar
oem pistons? built for boost? is the gap on the rings alittle bit bigger for boost?
Old Jul 25, 2011 | 07:39 PM
dallas306's Avatar
The bottom end is stock: No special gaps, oem pistons, rings, etc...
I never said it was a fully built motor, I rebuilt it but kept the bottom end stock, The only reason I said "built for boost" was because I didnt want to answer the "why the cams and springs" questions. Just a mild build for a fun street car. Any idea's?
Old Jul 25, 2011 | 11:37 PM
were the rings clocked correctly?
i would think it would be
rings
valve stem seals
valve guides
Old Jul 26, 2011 | 06:24 AM
dallas306's Avatar
rings were clocked correctly. Valve seals are new. But is it possible that a few valve seals could have torn on initial start up because of how long the engine sat?
Old Jul 26, 2011 | 09:14 AM
u should do a compression and leak down test just to see the numbers
90datech
May 13, 2008 07:10 AM
93'colttsi
Sep 23, 2007 10:51 PM
SIXTY-1HATCH
Dec 13, 2006 04:41 AM
SIXTY-1HATCH
Dec 11, 2006 11:30 AM
Cyber ITR
Aug 6, 2002 03:17 AM
