Car starts then dies ? ?
Old Jul 25, 2011 | 11:01 AM
olschool92's Avatar
Default Car starts then dies ? ?
My car will turn over but not start, but when it does start it will die. Sometimes this will not happen at all and it starts fine. And when it eventually starts it wont die like at the lights or while driving it. Its just when I go to start it sometimes.
I would say it starts fine like 85% of the time but 15% of the time it just turns over and like I said if it starts when its doing this it will die right away.
I have a new cap on it and new spark plugs, the wires are old.
Any ideas ? ?
Old Jul 25, 2011 | 11:15 AM
virgineg6's Avatar
Default Re: Car starts then dies ? ?
Does the fuel pump prime? Should be a buzzing or humming coming from the rear seat are. You might also be able to hear a clicking coming from behind the dash fuse box
Old Jul 25, 2011 | 11:20 AM
Former User's Avatar
When it won't start, check for spark and fuel.
Depending on what you find, resolder the main relay and/or have the igniter unit and coil tested.
Old Jul 25, 2011 | 11:31 AM
olschool92's Avatar
Cool thanks for the help this has definitely been a wired problem ive been so lost.
Old Jul 25, 2011 | 11:40 AM
frankenghia's Avatar
A new main relay from honda is only like 60-70 bucks. I would be willing to bet thats what it is. Very easy to install.
Old Jul 25, 2011 | 11:54 AM
olschool92's Avatar
I went to the car and put the key in and just turned it till I could here the fuel pump prime. I primed 15 out of 20 times I did it. 5 times it did not prime. Should it not prime every time ? ?
Old Jul 25, 2011 | 12:36 PM
olschool92's Avatar
Yea im starting to think its the main relay from what ive been reading. It seem to be a problem for our cars, thanks so much for your help =]
Old Jul 25, 2011 | 02:07 PM
HondaPartsHero's Avatar
Technical Hero
Some helpful info for ya
http://techauto.awardspace.com/mainrelay.html
Old Jul 25, 2011 | 02:38 PM
olschool92's Avatar
Originally Posted by HondaPartsHero
Thanks alot man, I checked my main relay and it had the problems so I grabbed one from Honda =] So far so good =]
bart simpson
15
Apr 6, 2010 12:21 PM
JASIYAH6
May 28, 2009 10:10 AM
ge_itr
Jun 1, 2007 09:00 AM
rex_racer728
Aug 21, 2005 05:12 PM
.ShawnD.
Aug 31, 2002 02:57 PM
