99 civic si gas problem
Sup guys i just bought a 99 civic si for cheap but the only problem is that is wasting alot of gas and idk why... Motor is stock it only has a fpg and intake what u guys think it could b?
start with a full tune up..
Rotor
Cap
Plug Wires
Plugs
Fuel Filter
New Oil
Seafoam or BG44K
make sure your brakes are not dragging
and tire pressure
also check if your gas cap is holding pressure
Rotor
Cap
Plug Wires
Plugs
Fuel Filter
New Oil
Seafoam or BG44K
and tire pressure
Or, you could tell us what fuel pressure you're at. What if there is a regulator that he doesn't know of that the previous owner jacked up? Why would you buy a fpg if you weren't going to mess with the fuel pressure?
The gauge read 40 it doesnt have a fpr idk y he would install a gauge witout having a fpr...
I was thinkin on buyin the seafoam and see what it does...
-Tell us exactly what you did for a tune up.
-Your engine must have an FPR. If it doesn't, that one major problem.
-Calculate your miles per gallon (mpg) for several tanks of gas. Otherwise, we have no idea whether your mpg is really bad.
If you want help, then provide detailed information.
