97 civic shaking bad
"i have a 97 civic with a b16a jdm swap my car shakes badly between 25-40 mph. and then on the highway at about 70. i just had new alignment and tires rotated and balanced following new inner and outer tie rods as well as new cv axles. what is my problem pl ..."
Mine also did that, and I did pretty much everything OP did to correct this.
I found out that one of my tires wasn't 100% round (cheapies) and when I bought new tires, the vibrations went away...........for a while.
I installed a ST front sway bar last night. Switched to gsr front CAs, and everything went on without trouble.
After testing it out on the road, it was running great, but when I got on the highway this morning, the steering wheel started shaking like Robert Downy jr at a coke party! I swear, I thought my damn tires were going to come off. I pulled over and checked them, they were good.
Only when I get to around 80mph. Under 75, nothing. Over 95, nothing. I am truly confused by this.
I have a 96 DX hatch btw.
I'm starting to think it may be the steering wheel. I put ans S2000 wheel, and noticed a tiny bit of slack when turning the wheel quickly to the left and right.
I might be crazy, but I'll try throwing the stock wheel back on and see what happens.
I've already checked ball joints and no leaking...
I'll see if the wheel is the culprit.
I took the steering wheel off and all splines are what they are supposed to be, but I still feel there is slight play in the wheel when installed.
I guess this whole situation is causing parinoia.
Taxpayer779
Nov 30, 2018 11:01 AM
whiteformula98
11
Nov 9, 2015 06:58 AM
BrayzieEF9
19
Jun 30, 2010 02:42 PM
